lipeschumacher
[VENDO] Amplificador Kenwood Excelon x700-5 ( 5 canais )
Vendo modulo Kenwood Excelon x700-5 ( 5 canais )
Valor: R$780,00
Modulo de extrema qualidade e potência!!quem conhece sabe. Não se compara a nenhum modulo nacional.
4 canais de 50w + 1 canal de 500w em 2ohm
Obs: Quando foi retirado do carro o instalador danificou os suportes do parafuso que prendem o modulo. Conforme fotos.
Features
5-channel car amplifier
40 watts RMS x 4 at 4 ohms + 300 watts x 1 at 4 ohms
50 watts RMS x 4 at 2 ohms + 500 watts RMS x 1 at 2 ohms
100 watts RMS x 2 bridged at 4 ohms + 500 watts RMS x 1 at 2 ohms
CEA-2006 compliant
variable low-pass filter on subwoofer channel (50-200 Hz at 24 dB per octave)
separate variable high-pass filters on front and rear channels (50-200 Hz at 12 dB/octave)
variable bass boost on sub channel (0-18 dB at 40 Hz)
cooling fan
preamp inputs
fuse rating: 40A x 2
4-gauge power and ground leads recommended — wiring and hardware not included with amplifier
12-3/4"W x 2-3/16"H x 7-3/8"D
Vejam as opniões do dono no site abaixo
Acessem :
https://www.crutchfield.com/S-5jirMLvPy2e/p_113X7005/Kenwood-Excelon-X700-5.html
Envio via mercadolivre:
Segue link do anuncio:
https://produto.mercadolivre.com.br/MLB-942305012-modulo-kenwood-excelon-x700-5-5-canais-alpine-hertz-focal-_JM
Visitante
