Lendario
[Vendido] Rockford Fosgate Punch 500a2
ROCKFORD FOSGATE PUNCH 500a2
Dynamic Power Rating (IHF-202 Standard) - Measured at 14.4 Volts
Mono into a 4ohms Load: 710 Watts x 1
Per channel into a 2ohms Load: 330 Watts x 2
Per channel into a 4ohms Load: 210 Watts x 2
Continuous Power Rating (Competition Standard) - Measured at 13.8 Battery Volts
RMS continuous power per channel, both channels driven into a 4ohms load from 20 to 20,000 Hz with less than 0.05% Total Harmonic Distortion (THD): 125 Watts x 2
RMS continuous power per channel, both channels driven into a 2ohms load from 20 to 20,000 Hz, with less than 0.1% Total Harmonic Distortion (THD): 250 Watts x 2
RMS continuous power mono into a 4ohms load from 20 to 20,000 Hz, with less than 0.1% Total Harmonic Distortion (THD): 500 Watts x 1
Signal-to-Noise Ratio > 100dB A-weighted
Crossover Slope 12dB/octave Butterworth
Crossover Frequency 80Hz 80Hz 50Hz ? 210Hz 50Hz ? 210Hz 50Hz ? 210Hz 50Hz ? 210Hz
Editado por Lendario
