japabr
Amp Rockford Fosgate P1000X5D é bom?
Galera, to montando um set e quero extrair o máximo do 3 way da HU 80PRS, surgiu uma oportunidade de pegar o amp Rockford Fosgate P1000X5D, alguém ja ouviu ele? é bom pra sq de entrada/intermediario?
o set é composto por:
-kit 2vias Audiophonic KC6.3
-sub Questo de 8" com 250w rms
Ficha técnica do amp:
CEA-2006 Compliant: CEA-2006_icon.gifCEA-2006 Power Rating
75Wx4 + 150Wx1 @ 4Ω
≤1.0% THD+N
Number of Channels: 5
Rated Power
(RMS Continuous Power): 75 Watts x 4 + 150 Watts x 1 @ 4-Ohm
125 Watts x 4 + 300 Watts x 1 @ 2-Ohm
n/a + 500 Watts x 1 @ 1-Ohm
Total Power
(Sum of Rated Power): 1000 Watts RMS
Dynamic Power
(PVC/PowerCube®): 101 Watts x 4 + 263 Watts x 1 @ 4-Ohm
150 Watts x 4 + 415 Watts x 1 @ 2-Ohm
n/a + 683 @ 1-Ohm
Bridgeable: Yes
(front/rear channels)
Frequency Response: Front/Rear: 20Hz - 20kHz +/-3dB
Sub: 20Hz - 500Hz +/-3dB
Efficiency (average): Front/Rear Channels: 85% @ 4-Ohm
85% @ 2-Ohm
Sub Channel: 85% @ 4-Ohm
85% @ 2-Ohm
Total Harmonic Distortion(THD+Noise): Front/Rear 4-Ohm: <1.0%
Front/Rear 2-Ohm: <1.0%
Sub 4-Ohm: <1.0%
Sub 2-Ohm: <1.0%
Sub 1-Ohm: <1.0%
Crossover Controls: Front: 50Hz - 500Hz High-Pass @ 12dB/Octave
Rear: 50Hz - 500Hz High-Pass @ 12dB/Octave
Sub: 50Hz - 500Hz Low-Pass
Sub: 25Hz infrasonic filter @ 24dB/Octave
Tone Controls: Sub:
0dB to +18dB @ 45Hz
0°/180° Variable Phase
Input Sensitivity: 150 mV to 12 V
Signal Input: Input Switch: Hi/Low level input
Input Switch: 2/4 channel input
Hi/Low Level: 3 RCA Pair
Sub: front/sub input switch
Signal Output: n/a
Power Input Connector: Block
Power Wire Gauge: 4 AWG
Speaker Output Connector: Block
Speaker Wire Gauge: 12 AWG
Heat Sink Type: Cast
Cooling: Convection
Remote Controls: Optional PEQ Remote Punch EQ
(overrides Sub Channel built-in Punch EQ2)
Visual Indicators: Power
Thermal
Protect
Circuit Topology Class: Full Range Class-D
Operating Voltage: 9 - 16 VDC
Recommended Fuse
(not included): 150 A
Max. Current Draw (13.8V Sinewave): 150 A
Average Current Draw (13.8V Music): 75 A
Suggested Alternator: 100 A
Shipping Weight: 11 Lbs. (4.98 Kg.)
Dimensions (H x W x D):
http://www.rockfordfosgate.com/products/details/p1000x5d
2.2 x 8.1 x 11.9 (in)
5.6 x 22.6 x 30.2 (cm)
