Padamar
[VENDO] Amplificador Rockford Fosgate Power T10001bd
Vendendo Amplificador Rockford Fosgate Power T10001bd, que dispensa descrições.
Ele está completo com o controle de grave original e inclusive com a caixa original, manual e certificado.
Estou vendendo pois vendi o carro.
O equipamento esta em São Paulo-SP. Se quiser pode retirar pessoalmente.
Equipamentos 100% funcionando, sem detalhes.
- 1x Amplificador Rockford Fosgate Power T10001bd ***VENDIDO***
Fotos mandar mp que envio por e-mail.
Product Highlights:
500 watts RMS x 1 at 4 ohms (750 watts RMS x 1 at 2 ohms)
1000 watts RMS x 1 at 1 ohm (1-ohm stable)
frequency response 20-250 Hz
Class bd technology
CEA-2006 compliant
requires 1/0-gauge power and ground leads — wiring and hardware not included with amplifier
variable low-pass filter (32-250 Hz, 24 dB/octave)
Para-Punch bass EQ (0-18 dB with variable center frequency between 35-70 Hz) with wired remote control
MOSFET power supplies and outputs
MEHSA mounting technology increases the heat transfer from the MOSFET output devices to the heat sink, for higher power output, lower operating temperatures, and greater reliability.
TOPAZ noise-killing differential inputs eliminate 80% of ground loop noise between the head unit and the amp.
TRANS-ana circuitry keeps preamp signal clean
NOMAD advanced protection circuitry monitors temperature, voltage, current and impedence, and provides "intelligent" shut-down protection without limiting system performance.
fan cooled
preamp outputs for easy connection to a second amplifier
bd Sync terminal for connection to a second bd amplifier, to drive a common load
fuse rating: 150A x 1
dimensions: 17-15/16"W x 2-11/16"H x 12-3/4"D
Features and Specs
Performance
RMS Power Output (Watts x Channels) 500 x 1
Peak Power Output (Watts x Channels) N/A
Power at 2 Ohms (Watts x Channels) 750 x 1
Bridged Power (Watts x Channels) N/A
Minimum Impedance Bridged N/A
Minimum Impedance Unbridged 1
Best Frequency Response 20-250 Hz
THD at Rated RMS Power 0.05%
Signal to Noise Ratio 80 dB
Input Voltage 14.4v
Features
Amplifier Class BD
Low-Pass Crossover Frequency 32-250 Hz
Low-Pass Slope (dB/octave) 24 dB
High-Pass Crossover Frequency N/A
High-Pass Slope (dB/octave) N/A
Bass Boost 0-18 dB
Bass Boost Frequency 35-70 Hz
Fan Cooled Yes
Fuse Rating 150 x 1 (ANL)
Speaker Level Inputs No
Preamp Outputs 1 pair
Width (inches) 17-15/16
Height (inches) 2-11/16
Depth (inches) 12-3/4
Editado por Padamar
