Reginaldocm
AudioControl DSP em amplificador
AudioControl Enters Hi-Res Car Audio
AudioControl announced a pair of new amplifiers and two digital signal processors (DSPs) that all support Hi-Res Audio.
The two DSPs also now include a Bluetooth port to allow Hi-Res Audio streaming at 96kHz from a smartphone to a car audio system.
“…AudioControl strongly supports the transition to Hi-Res Audio or Lossless audio in the car that is capable of reproducing the full range and content of sound the way the artist intended,” said Chris Kane.
The processors and one of the new amplifiers are also unique in that they have real time analyzers (RTAs) on both the inputs and outputs, which AudioControl claims is a first for the industry. Installers can see the audio signal both coming in and leaving the devices.
And one of the new processors is the most flexible on the market, with 10 outputs, said AudioControl,
Both of the new processors are designed and built in the US, and they include 24-bit/96K digital to audio converters.
“We spent a lot of time engineering the software so it’s different. It’s very intuitive. The key to DSP is really software and how it’s installed and integrated. When we were engineering, we tried to make it simple to use. Instead of 4 hour tuning time, we hope to cut that in half since all the tool and installer needs are built into the software,” said AudioControl CEO Alex Camara.
A new DM-810 processor has 8 active high level speaker inputs, 6 preamp inputs, 2 digital inputs plus 10 preamp outputs. Each input can be tuned and you get 10 controllable outputs to handle even very large audio systems.
The Bluetooth port works with a Bluetooth module to pair with a smartphone or tablet (Android or iOS) to make adjustments to the user interface as well as deliver music streaming.
A scaled down processor is the DM-608 with 6 inputs and 8 outputs in a smaller footprint. You still get RTAs on the inputs and outputs, and a digital input.
AudioControl is also moving deeper into the category of amplifiers, which it launched for the first time last year. The two new 2016 models are the company’s first full range models, one with built-in DSP.
Amp model D-4.800 with DSP lets you correct, process and amplify your audio with one box. It is a 4-channel digital amplifier with a matrixing DSP. It’s rated at over 200 watts RMS at 2 ohms and it has 6 active high-level speaker inputs that can be summed and individually controlled using DSP. With a PC interface you can also correct time alignment and phase on both inputs and outputs.
If the installer is confused about which signal is coming in and which is signal is going out, he can view the input and output RTAs and make adjustments to the 30 band graphic equalizer. To save time, he can adjust the audio’s time alignment by entering a distance in numbers via a slider, or he can do his own calculation and input a delay by milliseconds.
A second new amplifier is the LC-4.800. It is a 4-channel model with 6 active high-level speaker inputs and 200 watt RMS power at 2 ohms and 150 watts at 4 ohms.
All models are expected to start shipping in early 2016 and carry a 5-year limited warranty.
They will be on view at the CES Show next month at booth #2112 in the North Hall of the Las Vegas Convention Center.
Versão Google traduz,
AudioControl anunciou um par de novos amplificadores e dois processadores de sinal digital (DSPs) que todo o apoio Hi-Res Áudio.
Os dois DSPs também incluem agora uma porta Bluetooth para permitir Hi-Res Áudio Streaming a 96kHz a partir de um smartphone para um sistema de áudio do carro.
"... AudioControl apoia firmemente a transição para Hi-Res áudio ou Lossless áudio no carro que é capaz de reproduzir toda a gama eo conteúdo de som do modo que o artista", disse Chris Kane.
Os processadores e um dos novos amplificadores também são únicos em que eles têm analisadores em tempo real (ACR) em ambos as entradas e saídas, que AudioControl afirma ser um primeiro para a indústria. Os instaladores podem ver o sinal de áudio tanto entrando e deixando os dispositivos.
E um dos novos processadores é a mais flexível no mercado, com 10 saídas, disse AudioControl,
Ambos os novos processadores são projetados e construídos em os EUA, e que incluem 24-bit / 96K digital para conversores de áudio.
"Passamos muito tempo engenharia do software por isso é diferente. É muito intuitivo. A chave para o DSP é realmente software e como ele é instalado e integrado. Quando estávamos engenharia, nós tentamos torná-lo simples de usar. Em vez de 4 horas tempo de ajuste, esperamos que cortar ao meio uma vez que todas as necessidades de ferramentas e instalador são incorporadas ao software ", disse o CEO AudioControl Alex Camara.
Um processador DM-810 nova tem 8 entradas de ativos de alto nível de alto-falante, 6 entradas pré-amplificador, 2 entradas digitais, além de 10 saídas pré-amplificador. Cada entrada pode ser sintonizado e você terá 10 saídas controláveis ​​para lidar com mesmo muito grandes sistemas de áudio.
A porta Bluetooth funciona com um módulo Bluetooth para emparelhar com um smartphone ou tablet (Android ou iOS) para fazer ajustes na interface do usuário, bem como entregar streaming de música.
Um processador é reduzida a DM-608 com 6 entradas e 8 saídas em um espaço menor. Você ainda obter ACR sobre as entradas e saídas e uma entrada digital.
AudioControl também está se movendo mais fundo na categoria de amplificadores, que foi lançado pela primeira vez no ano passado. Os dois novos modelos de 2016 são os primeiros modelos da série completa da empresa, um com built-in DSP.
Modelo D-Amp 4.800 com DSP permite corrigir, processo e amplificar o áudio com uma caixa. É um amplificador digital de 4 canais com um DSP matrixing. É avaliado em mais de 200 watts RMS em 2 ohms e tem 6 entradas de alto-falante de alto nível ativos que podem ser somados e controlados individualmente através de DSP. Com uma interface PC você também pode alinhamento de tempo correto e de fase em ambas as entradas e saídas.
Se o instalador é confuso sobre qual sinal está chegando e que é sinal está saindo, ele pode visualizar os ACR de entrada e saída e fazer ajustes para o equalizador gráfico de 30 bandas. Para economizar tempo, ele pode ajustar o alinhamento de tempo do áudio, inserindo uma distância em números através de um controle deslizante, ou ele pode fazer o seu próprio cálculo e introduzir um atraso de milissegundos.
Um segundo novo amplificador é a LC-4.800. É um modelo de 4 canais com 6 entradas de ativos de alto nível e de alto-falante de 200 watts RMS de potência em 2 ohms e 150 watts em 4 ohms.
Todos os modelos são esperados para iniciar a navegação no início de 2016 e têm uma garantia limitada de 5 anos.
Eles vão estar em exibição na CES Show próximo mês no estande # 2112 no Salão Norte do Centro de Convenções de Las Vegas.
