Reginaldocm
Lançamento da Clarion multimídia interessante
Clarion Corporation announced a new navigation deck that supports Hi-Res Audio FLAC files and that works with the industry’s first all digital car audio system.
The new in-dash double DIN NX706 is compatible with Clarion’s new Full Digital Sound Components system that keeps the signal digital through to the speakers without the need for an amplifier or digital-to-audio converters.
“With the growing trend toward high-resolution lossless audio, we designed the NX706 for customers who want the absolute best possible sound quality from their car audio system,” said Clarion VP Marketing and Product Planning Allen Gharapetian.
It supports 96kHz audio and uses TOSLINK (a standard digital optical connection) output to connect to other components. It also has a 7-inch WVGA touch screen, HDMI, two USB inputs and a 15-band parametric eq with low pass and high pass filters.
Users also get Bluetooth, Pandora control and backup camera input with audio. The NX706 is also SiriusXM ready. Suggested retail price is $799.99.
Clarion’s Gharapetian said of Clarion’s FDS system, “This full digital signal capability from source to speaker is an industry first for aftermarket car audio systems and the sound quality provided by it is breathtaking. To push the envelope further, we implemented an audiophile quality 15-band parametric EQ for our customers to achieve that ‘perfect’ sound.”
Under the FDS system the digital signal is divided into 6 digital signals that are sent to a digital processor and transferred to a 6 layer voice coil that directly drives the speakers. It incorporates the drive circuit into the speakers so there’s no need for an amplifier.
The audio signal for each channel in the system remains digital all the way to the voice coil, ensuring that high-resolution digital audio is maintained without loss or added noise and artifacts from analog connections, said Clarion.
The NX706 and FDS system will be on display at CES January 6-9 at the Westgate Lobby adjacent to the Las Vegas Convention Center. More details on how the FDS system works is expected to be revealed at that time.
Google:
Clarion Corporation anunciou uma nova plataforma de navegação que suporta arquivos de áudio Hi-Res FLAC e que funciona com o primeiro todo o sistema de áudio do carro digital da indústria.
A nova dupla NX706 DIN in-dash é compatível com o novo sistema Componentes do Clarion Digital completa de som que mantém o sinal digital por meio dos alto-falantes sem a necessidade de um amplificador ou conversores de digital para áudio.
"Com a crescente tendência de alta resolução de áudio lossless, nós projetamos a NX706 para clientes que querem a melhor qualidade de som possível absoluta do seu sistema de áudio do carro", disse Clarion VP de Marketing e Planejamento de Produto Allen Gharapetian.
Ele suporta áudio de 96 kHz e usa TOSLINK (a óptica digital padrão de conexão) de saída para se conectar a outros componentes. Ele também tem uma tela de 7 polegadas WVGA touch, HDMI, duas entradas USB e um equalizador paramétrico de 15 bandas com filtros passa-baixa e alta passagem.
Usuários também terá Bluetooth, controle de Pandora e entrada de câmera de backup com áudio. O NX706 também é SiriusXM pronto. Preço sugerido é de $ 799,99.
Gharapetian do Clarion disse de sistema FDS da Clarion, "Esta capacidade de sinal digital completo da origem para o alto-falante é o primeiro da indústria para sistemas de áudio do carro aftermarket e a qualidade do som fornecido por ele é de tirar o fôlego. Para empurrar o envelope ainda mais, implementamos uma qualidade audiófilo equalizador paramétrico de 15 bandas para os nossos clientes para alcançar esse som 'perfeito' ".
Sob o sistema FDS o sinal digital é dividida em 6 sinais digitais que são enviados para um processador digital e transferidos para uma bobina de voz 6 camada que aciona diretamente os alto-falantes. Ele incorpora o circuito de carro para os alto-falantes por isso não há necessidade de um amplificador.
O sinal de áudio para cada canal no sistema permanece digital de todo o caminho para a bobina de voz, garantindo que de alta resolução de áudio digital é mantida sem perda ou ruído e artefatos adicionada a partir conexões analógicas, disse Clarion.
O sistema NX706 e FDS vai estar em exibição na CES janeiro 06-9 no Westgate Lobby junto ao Centro de Convenções de Las Vegas. Mais detalhes sobre como o sistema funciona FDS é esperado para ser revelado naquele momento.
