Henrique A3
Sundown Audio - SAX-100.4D
Boa noite, Alguem conheçe esse amp?
Quem me indicou foi o Julian da woofersetc.com, mas nauca ouvi falar
Alguem ai pode me ajudar?
SAX-100.4D - Sundown Audio 100W 4-Channel Amplifier
Rated power output
RMS power, 4 ohm stereo
100W x 4CH
RMS power, 2 ohm stereo
160W x 4CH
RMS power, 4 ohm bridged
320W x 2CH
Signal to Noise Ratio >90dB
Low pass frequency crossover
50Hz~5kHz (CH1&2)
50Hz~5KHz (CH3&4)
(50-500 with x10 switch)
Selectable 12 or 24 dB slope
High Pass Crossover
50Hz~5kHz (CH1&2)
50Hz~5kHz (CH3&4)
Variable Subsonic Filter 10Hz to 500Hz
Frequency Response 10Hz ~ 40KHz (+/-1dB)
Bass Boost 0~18dB
Variable Bass-Boost Frequency Control 35Hz to 120Hz
THD@RMS Watts <0.1%
Channel Separation 75dB
Fuse Rating 30A x 3
Input Sensitivity Variable 200mV~6V (+/- 5%)
Dimensions 252(W) x 58(H) x 480(L)mm
Editado por Henrique A3
