juniorcasm
[Ford Escort] - SQ de Entrada...
Fala ai pessoal.
Comprei uns equipamentos para montar meu som, segue lista deles:
Kit 2 Vias Pioneer Tse 136c (5" - 70rms - 4ohms)
Sub NAR 12" 1204-SW2 (200rms - 4ohms)
Ampli Eclipse 36401
105 Watts x 4 Channel Max. Power Output at 2W Stereo (420 Watts total max)
60 Watts x 4 Channel 0.1% THD at 2W Stereo @13.8V (RMS Continuous Power)
40 Watts x 4 Channel 0.1% THD at 4W Stereo @13.8V (RMS Continuous Power)
ChannelFlex Crossover
Adjustable High-Pass Frequency (50 - 200Hz, L/R Independent)
Low-Pass Frequency (120Hz)
Adjustable Bass-Boost Level (45Hz, 0 - 9dB, F/R Separate)
High-Current, High-Speed Output Devices
High-Efficiency, High-Energy MOSFET Power Supply
Audiophile Grade Component Selection
Intelligent 7-Way Discrete Protection Circuitry
Noise Reduction with Low Distortion & Ultra-Low Negative Feedback
High-Level Input - Add on Capability
Epoxy Composite PCB
2W Stable Design
http://i.imagefra.me/084hqmuy
http://i.imagefra.me/5b1hqmv2
http://i.imagefra.me/e2bhvef3
(fotos retiradas do anuncio do gudoido2005)
OU
Ampli Lanzar Vibe 530
RMS Power @ 4 Ohms 75W x 4 + 100W x 1RMS
Power @ 4 Ohms 100W x 4 + 140W x 1
Bridged Power @ 4 Ohms 300W x 2 + 200W x 1
Dynamic Power @ 4 Ohms 150W x 4 + 200W x 1
Dynamic Power @ 2 Ohms 280W x 4 + 360W x 1
Bridged Power @ 2 Ohms 650W x 2 + 480W x 1
Min. Speaker Impedance 2 Ohm
THD 0.04%
Frequency Response: 15Hz-35kHz
Input Sensitivity 100mV-1000mV
Input Impedance 22kOhm
Signal-to-Noise Ratio >90dB
Channel Separation >65dB
Crossover Network: Low Pass Filter BPF
(Hi-Lo Variable) 40Hz-500Hz
Bass Boost 0 - +12dB
High Pass Filter 40Hz-4kHz
Dimensions: 10.25"W x 2"H x 24"L
Fuse Rating 30A x 2
http://www.yorks.com.br/yorks/02/promocao/modulos/foto47.gif
http://image.inkfrog.com/pix/vinyllust/lanzer5302sideview2fixed.jpg
http://image.inkfrog.com/pix/vinyllust/lanzer530fixed.jpg
Qual amplificador ficaria melhor?
O Eclipse é meu, comprei ele. O Lanzar é de um amigo, ele deixou comigo, falou que se me interessar ele fica com o Eclipse. O Lanzar precisa trocar os parafursos dos canais, estão enferrujados.
Se precisar passar mais infos me falem que tento colocar aqui.
eu ia comprar um lanza mais aqui no forum mesmo, falaram que ele mente na potencia e que nao tem boa qualidade pasmafaute
mais eu sou meio suspeito p falar ja que eu me amarro em tudo da eclipse
É, vou montar com o Eclipse, quando puder colocar outro ampli com mais potência pro sub.
Esse fds vou começar a montar... passar fios e cabos... e posto fotos!!
Vlw!!!!!!
