marcelomoti
Focal Beryllium BMW 323ci DIY
FONTE: http://www.audiogroupforum.com/csforum/showthread.php?t=66958
Este excelente DIY que dura já 2 anos é o melhor relato de montagem e uso de materiais combinados que eu já vi.
O uso de materiais como fibra de vidro, resina, fibra de carbono e alumínio são extensivamente usados com uma técnica que permite montar qualquer coisa.
Parece ser tão fácil quanto trabalhar com argila.
Confiram algumas fotos.
Quem ficar mais interessado, visite o fórum do autor desta façanha. http://www.audiogroupforum.com/csforum/showthread.php?t=66958
Here a picture of the bottomside, where he made wholes , to let the sound flow outside.
The wholes you can see in the alu, don't worry about it.
It'll be covered in CF..
some cupper
5mm thickness, more didn't fit in the speaker.
He let the alu triangles bade in a little CF.
some more CF.
This is the bottom plate where the box is put on.
sprayed it in black offcourse, don't want the colour of the wood come throu
Started to make a hinge. He went to see the store, but they didn't had what he needed. So got some aluminium ..
and made it myself
Editado por marcelomoti
A couple of years ago, my wife was making( read: painting) christmasballes, to hang in the christmastree. She also hooked on making special things
When I looked at the plexy balls, I know, that sometime, I could use it for another project Well, ladies and gents, IT'S TIME
These are the plexy balls, you can buy 'm in every size. (according to his wife)
In the meantime, Ie started to try some things with those christmasballs
They will go on horizontally against the A-pillar of the car. Later more info on this. I made already 4 copies in polyester.
Made a hole in it, and taped it all with some tape.
Then I polished it all a few times, so when he takes them apart, no polyester stays sticking on the plexy.
It also took some work to make the fiberglass so smooth with as less airbubbles as possible.
There are 2 layers of polyester now, what should be strong enough. Don't want these things to get TOO heavy.
Made another 4 alu-rings that will come in there. So it will be possible to screw the speakers tight into the alu rings.
It also popped to mind that it would be cool to cover this in CF, but that's almost not possible.
The polyester balls are ready, and look good.
On the right bal, you see a piece of polyester go loose from the plexy.
Ticked it with a hammer.
removed the plexy (upper)
Cause I didn't want to change his original 16:9 screen in the console, I had to find a place for the ALPINE CDA-7998 Phantom Face.
I wanted to do this in the middle, under the armrest. Then I had to get of the front en extend it with cables. If this was an ordinary radio, no problem, but with this radio I didn't want to take the risk.
So looked for another option to place the radio, without doing harm to the looks of the interior.
Made little trolley to fasten the radio.
