Ianaconi
Novidades - Ianaconi Imports
PS8 Set up and user defined custom features-
· Standard User Mode-
1. Input Signal Menu and capabilities-
§ User adjustable input signal level per channel
§ Variable adjustability of input signal from -64Db - +24Db in 1/2 Db per step increments per channel
§ User defined input auto sense source select.
§ User defined auto sense priority interface (Gives users the ability to pick what input source users choose to have automatically default to if the main unit senses the signal such as defaulting to Bluetooth from normal analog RCA operation)
§ Analog (RCA, 3.5mm Unbalanced) inputs and Bluetooth operations only. (Digital Coaxial & Optical Not Available)
2. Signal Path Router Panel and capabilities-
§ Input / Output installer assigned channel assignment
§ Installer defined signal path assignment allows for any channel input signal to go to any output channel signal (on/off)
§ User friendly Sum/Mono button allows users to combine any input combination of paired channels into a single 100% unclipped Sum Mono signal for subwoofer applications.
§ Numerical value displays for all possible interesting assignment paths
§ User adjustments can be made by manual entry, mouse pointer via dial control, double key stroke (Channel On and Off) and arrow key control
§ Individual 180 degree signal phase invert on all 8 output channels (Mirrored controls on Signal Delay Panel as well)
3. Crossover settings panel-
§ 8 Channels out full open architecture selectable type crossovers All Pass, High Pass, Low Pass, Band Pass
§ Fully open architecture crossover slopes allow users to select any variation of slope on any filter type with abilities for different slopes on both HP and LP portions of BP configuration
§ Fixed Crossover slope selection on all channels at 12Db/24Db Selectable
§ Butterworth damping on all bands of all channels
§ User defined variable frequency selection on every band of every channel from 20Hz thru 20kHz.
§ Slider, keyboard arrow key and numerical entry options for all crossover setting.
§ User defined frequency limitations platform to prevent adjustments being made below defined frequency points preventing damage to speakers during the tuning process
4. Phase/Signal Delay Panel-
§ No Signal Delay Available in Standard User mode
§ 0/180 Degree switchable phase on all 8 channels of output
§ Individual 180 degree signal phase invert on all 8 output channels (Mirrored controls on Signal Router Panel as well)
5. Parametric EQ
§ 10 Band Parametric EQ across all 8 Channels of output Frequencies (Not individual channel adjustment)-
1) Freq 50Hz Q- 9.427
2) Freq 75Hz Q- 6.075
3) Freq 125Hz Q- 4.763
4) Freq 315Hz Q- 3.015
5) Freq 750Hz Q- 4.909
6) Freq 1.25Hz Q- 5.201
7) Freq 2.2kHz Q- 5.050
8) Freq 5.0kHz Q- 4.306
9) Freq 8.0kHz Q- 6.366
10)Freq 14.0kHz Q7.241
§ All bands adjustable in 1/2dB increments
§ +/- 10dB on all 10 bands of equalization
§ Adjustments can be made with Mouse Pointer, manual numerical entry and keyboard arrow controls allowing users the opportunity to tune with their ears and not their eyes.
6. Output Signal Panel
§ Each channel 0 thru -40/infinate dB attenuation per channel on the PS8 allows for users to reduce signal output for amplifiers that cannot accept high signal level input and for advanced system calibrations
§ F+R, L+R, Center and Bass level faders easily accessible on this panel for user defined tuning and level setting.
· OEM User Mode-
§ Six Channels Analog User adjustable input signal level per channel
§ Optional Digital Coaxial or Optical Source Input
§ Variable adjustability of input signal from -64Db - +24Db in 1/4 Db per step increments per channel
§ User defined auto sense priority interface (Gives users the ability to pick what input source users choose to have automatically default to if the main unit senses the signal such as defaulting to a digital source from normal analog operation)
§ Input VU meter is positioned and fixed to this screen. (Every time this section is accessed the Input VU meter is part of the listing of meters and information to assist with signal summing and OEM integration to dedicated frequency OEM systems.)
2. Signal Path Mixer/Router Panel and capabilities-
§ Universal router panel disabled in OEM mode.
§ All inputs combined in direct full range output to all 8 output channels
§ User defined channel filters allow any output to be summed full range or pass thru from and of the 6 analog inputs for dedicated OEM frequency band (default 8 channels full range, odd channels left channel even channels right channel)
§ User adjustments can be made by manual entry, mouse pointer via drop down selection list and arrow key control
I. Operation- User can define each intersecting input to output assignment either as “Summed” or as Ch 1 Pass, Ch 2 Pass, Ch 3 Pass, Ch 4 Pass, Ch 5 Pass, and Channel 6 Pass depending on the intersecting location on the router page.. (recommend a drop down box that the options can be within to save space on the mixer screen at each of the intersecting points.) This will give users the option for either summed output signal on any of the 8 channels of output
II. Mono Output- If the user chooses to combine the L&R information from 2 inputs since there is no variable mixer there needs to be a intersecting check box between 2 channels such as channel 1&2 in to Channel 8 out that can be checked that will reduce the mixer level by 50% on each input channel to allow the user to achieve a unclipped sum mono signal out of the mixer.
§ Fixed Crossover slope selection on all channels at 6Db, 12Db, 18Db, 24Db, 30Db, 36Db, 42Db, 48Db
§ User defined damping options on all bands of all channels including Butterworth & Linkwitz-Riley
§ User defined damping are allowed mixed variable on Bandpass crossovers giving users options, for example of Linkwitz-Riley on the Low Pass and Butterworth on the High Pass
§ User defined variable frequency selection on every band of every channel from 20Hz thru 20kHz. Users can define crossover points such as 6523.43Hz if desired
§ 8 Channels user defined signal delay
§ Delay up to 10ms per channel
§ Signal Delay adjustable in .05ms increments
§ Numerical display readout on all channels for real time delay status
§ Slider, keyboard arrow key and numerical entry options for all delay setting
§ Global/Relative likability of any combination of channels allowing users to adjust delay on each channel individually and then in pairs or globally without the loss of the previous individual channels setting.
§ Individual 180 degree signal phase invert on all 8 output channels (Mirrored controls on Mixer Panel as well)
5. Equalization panel-
§ 8 Channels 31 band Third Octave Equalization
§ Traditional 1/3rd Octave EQ points from 20Hx - 16kHz
§ Adjustable in 1/2 Db per step increments
§ Each band per channel adjustable +/- 15Db
§ Global/Relative/Individual likability of any combination of channels allowing users to adjust the EQ on each channel individually and then in pairs or globally without the loss of the previous individual channels setting. TRUE GLOBAL CAPABILITY!
6. Output Signal Panel-
· Intermediate User Mode-
· Expert User mode-
7. Input Signal Menu and capabilities-
8. Signal Path Mixer/Router Panel and capabilities-
§ 100% Fully open architecture variable mixer panel controls
§ User defined signal path from any input channel configuration to any output channel configuration
§ All Mixer/Router channel in/out assignments are fully variable allowing uses to select any level of input signal to its out channel assignment allowing for stereo, mixed stereo, mixed mono, sum mono signal assignments and more.
§ User friendly Sum/Mono button allows users to combine any input combination of paired channels into a single 100% unclipped Sum Mono signal.
9. Crossover settings panel-
§ User defined damping options on all bands of all channels including Butterworth, Linkwitz-Riley, Bessel and Brickwall
§ User defined damping are allowed mixed variable on Bandpass crossovers giving users options, for example of Linkwitz-Riley on the Low Pass and Bessel on the High Pass
§ Variable "Q" adjustment option on all crossover points from .2 - 5.0 per band per channel
§ User defined variable frequency selection on every band of every channel from 5.00Hz thru 20.00kH. Users can define crossover points such as 6523.43Hz if desired
§ PS8 Crossover Variations -
ü 1,999,500 Crossover frequency points per crossover type per channel
ü 3,999,000 Possible crossover frequency points per channel
ü 31,992,000 Possible crossover points on the PS8 over 8 channels
ü 15,356,160,000 Possible crossover types and configurations on the entire PS8
10. Phase/Signal Delay Panel-
§ Signal Delay adjustable in .01ms increments
§ Individual 180 degree signal phase invert on all input source channels
11. Third Octave Equalizer
§ Adjustable in 1/4 Db per step increments
§ Each band per channel adjustable +/- 24Db
§ Total 5952 1/3rd Octave Adjustment points per channel per band
§ Total 47,616 1/3rd Octave Adjustment points on the PS8 across 8 channels
§ Third Octave Equalizer Variations
ü 192 1/3rd Octave Adjustments per band per channel
ü 5952 1/3 Octave EQ Adjustments per channel
ü 47,616 1/3 Octave EQ adjustments on the PS8
12. Parametric Equalizer
1. 8 Channels of fully open architecture parametric equalization
2. User defined parametric equalization from 1 - 31 bands per channel
3. User defined frequency centers on all 31 bands of each of the 8 channels selectable from 5.00Hz - 20,000kHz (Any frequency including 16th octave harmonic frequencies and mid tones)
4. User defined "Q" on all user defined and factory frequencies on all channels.
5. "Q" adjustable from .1 - 24.0 allowing users to have the opportunity to select "Q" variations from wide banded configurations of 1/4 of 1Db per octave step to extremely sharp EQ points allowing for applications such as 31 bands of EQ notch filters on every channel if desired
6. Adjustable in 1/4 Db per step increments
7. Each band per channel adjustable +/- 24Db
8. Global/Relative/Individual likability of any combination of channels allowing users to adjust the EQ on each channel individually and then in pairs or globally without the loss of the previous individual channels setting. TRUE GLOBAL CAPABILITY!
9. Adjustments can be made with Mouse Pointer, manual numerical entry and keyboard arrow controls allowing users the opportunity to tune with their ears and not their eyes.
10. Lets calculate that...
ü 5952 Single frequency parametric EQ Adjustments per channel
ü 1,999,500 Selectable frequency points per band of equalization per channel
ü 24,000 points of variable "Q" per band of equalization per channel
ü 285,624,576,000,000 total variations on the PS8 Parametric Equalizer per channel ...
ü Time 8 channels of output
ü 2,284,996,608,000,000 total parametric variations on the PS8 equalizer (Two Quadrillion, Two Hundred and Eighty Four Trillion, Nine Hundred Ninety Six Billion, Six Hundred and Eight Million)
7) Output Signal Panel
Sim, claro.
O preço será similar ao Audison Bitone / PXA-H800.
Se for até o preço do bitone, vou pensar seriamente em um. Se for o preço do PXA então eu vou continuar pensando no bitone.
vc vai la de novo Diogo??? putz q vontade de ir!!!!!!
:+1 Morro de vontade de acompanhar um campeonato internacional! Deve ser coisa de louco!
Sim, o L3 Pro deve ser lançado esse ano.
Não irá substituir o L3 SE.
Será para aqueles que querem um midrange de instalação mais simples. Provavelmente terá FS em torno de 250Hz e tocaria até 12.000 Hz com uma profundidade de 44mm.
Foto de um protótipo alpha:
Editado por Ianaconi
Sim, mas não podemos comentar ainda. Só posso adiantar que vem um projeto slim totalmente diferente do que existe no mercado atualmente.
Previsão de lançamento: 10-11/2012
A final mundial da IASCA ocorre nesse final de semana em Daytona Beach, na Flórida.
A Arc Audio e também a Hybrid Audio estarão competindo em várias classes.
E aqui um preview do G35 do Scott Buwalda que irá competir:
