Leandrinhom
Bentely Mulsanne
Bentley Mulsanne – Technical Specification Summary
Engine
Type: Twin-turbocharged V8
Installation: Front, longitudinal, rear-wheel drive
Construction: Alloy heads and block
Capacity: 6750cc
Power: 512PS / 377kW at 4200 rev/min
Torque: 1020Nm at 1750 rev/min
Performance & Economy
0-100 km/h in 5.3s
0-160 km/h in 11.5s
Max Speed: 296 km/h
Economy: 16.9 l/100km Combined EU
CO2 emission: 393 g/km
Transmission
Type: Rear-wheel-drive
Gearbox: ZF 8-Speed automatic
Body & Chassis
Length: 5575mm
Width (mirrors folded): 1926mm
Height: 1521mm
Wheelbase: 3266mm
Front Track: 1615mm
Rear Track: 1652mm
Wheels / tyres (standard): 9J x 20in. with 265/45 ZR 20 tyres
(option): 9J x 21in. with 265/40 ZR 21 tyres
Kerb weight: 2585 kg
Bentley Mulsanne - Standard Feature Specification
Drivetrain
-6.75 litre twin-turbocharged V8
-512PS / 377kW at 4200 rev/min
-1020 Nm at 1750 rev/min
-Cam phasing and variable displacement – a first for the ultra-luxury sector
-EU5 and LEVII emissions compliant
-8-speed automatic transmission with electronic shift interface, sport mode and steering-wheel mounted paddleshift
-Rear-wheel drive
Chassis
-Mulsanne 20" light-alloy wheels with 265 x 45 x ZR20 tyres
-Double wishbone front suspension
-Multilink rear suspension with toe and brake reaction control. Uniquely developed for Mulsanne to handle extreme torque
-Electronically-controlled air springs with Continuous Damping Control (CDC) to continuously monitor and adjust the vehicle's damping, ensuring optimum control
-Automatic ride height control sensitive to speed and load
-Servotronic speed-sensitive power steering with two settings selectable by Drive Dynamics Control
-Drive Dynamics Control - four driver-selectable settings for CDC and power steering
-Three standard modes: Bentley, Sport and Comfort
-A fourth mode, Custom allows driver to 'tune' system to a preferred driving style
-Electronic Stability Control (ESC) with ABS, traction control, hydraulic brake assist, electronic brake prefill and automatic hill-hold control
-Twin-booster braking system with ventilated discs and Electronic Brake force Distribution (EBD)
-"Bentley" branded front brake calipers
-Front brake discs: Two-piece assembly with 400mm diameter x 38mm thick iron disc and lightweight aluminium hub
-Rear brake discs: 370mm diameter x 30mm thick iron disc with lightweight aluminium hub
-Electronic Parking Brake with drive-away assist and hill hold feature.
-Choice of tyre repair/inflation kit or spacesaver spare wheel & toolkit
Body & Exterior
-Steel monocoque body structure with front and rear energy-absorbing crumple zones
-Aluminium closures
-Superformed aluminium front wings
-Aluminium bonnet
-Aluminium doors with superformed structure and extruded aluminium side impact beams
-Composite polymer bootlid housing fully concealed antennae systems
-Painted radiator shell with bright stainless steel matrix grille and 2-D Bentley winged "B" badge
-Paintwork applied and polished by hand to a mirror-finish
-Choice of 28 paint colours especially selected for Mulsanne.
-Black matrix grille to lower bumper apertures
-Front wing vents with black matrix grille
-Polished stainless steel brightware to glass surrounds
-Polished stainless steel embellishers to doors and bumpers
-Door pillar finishers in steel with gloss black painted finish
-Polished stainless steel "Mulsanne" treadplates and commissioning plates
-Wide oval polished stainless steel exhaust tailpipes
-Twin bi-xenon projector headlamps with LED halo for supplementary main beam, light-sensing auto operation, daytime running light signature and integrated washer jets
-Floating-ellipse style, LED rear light clusters and discreet high-level stop lamp to rear screen
-Colour-keyed, electronically adjustable door mirrors with heating, power folding, reverse-dip, two memory positions, electrochromatic dimming and integrated puddle lamps
-Keyless entry system with chromed metal door handles and engine start button
-Soft close power latching to all doors for easy entry / exit
-Power boot lid operation with emergency releases inside boot and under rear seat
-Park distance control to front and rear with audible signal and graphics displayed via infotainment screen
Interior
-Hand-selected leather to all trimmed surfaces including seating, fascia, console, door panels, door pillars, parcel shelf, cantrails, headlining, sunvisors, all stowage compartments and glovebox
-24 'standard' colours in single tone or duo-tone combinations in four different styles (colour splits) allowing the customer to choose not just the colour scheme but the mood of the interior – from very elegant to sporty
-Specially developed, flat-cut and leather-bound carpet. Choice of 21 colours to match interior hide
-Set of four carpet overmats to match cabin carpet, leather bound and with polished stainless steel fixings
-Choice of 23 seatbelt colours with buckles colour-matched to interior hides
-Veneer to fascia, continuous "Ring of wood" waistrails, centre console, rear centre armrest, and front & rear roof consoles in burr walnut, dark-stained burr walnut or piano black. Six further veneer species are available
-Bright finish interior fittings in polished stainless steel
-Unique, glass-effect switchgear
-Driver's instrument panel featuring inverted, aviation-style dials for vehicle and engine speed; Supplementary colour screen displaying a driver-configurable choice of navigation prompts, compass, infotainment, vehicle or trip information
-Minor gauges panel in centre fascia with fuel gauge, analogue clock with "Bentley Motors" inscription and coolant temperature gauge
-Concealed passenger-side map lamp
-Boot trimmed in leather and carpeted to match interior cabin with polished stainless steel sill plate
Wheels & Tyres
-20" Mulsanne Alloy Wheel - Chromed
-21" Classic Alloy Wheel - Painted
-21" Classic Alloy Wheel - Polished
-21" Two Piece 5 Spoke Alloy Wheel - Painted
-21" Two Piece 5 Spoke Alloy Wheel - Polished
-Space Saving Spare Wheel - NCO (standard in Turkey, Bahrain, India, Kuwait, Oman, Qatar, Saudi Arabia & UAE)
Fonte: Bentley UK
