Drifitking
Subwoofer Soundstream R1 de 15 ( novas fotos )
VIDEO do soundstream tocando em uma selada com o agressive empurrando !!!
Soundstream
NOVAS FOTOS !!!!
correios do ca*****... tricou o acrilico do fundo do sub
http://www.soundstream.com/AudioProducts/S...1-reference.htm
Dual 3” Flat Wire Wound Voice Coil
• Copper Clad Aluminum Voice Coil Wire
• Dual Layer Aluminum Voice Coil Former for Extreme Strength
• All-in-One Discrete Mount Terminals
• Tall Motor Gap for Extended XMax
• Dual Large High Temp Ferrite Magnets
• Integrated Aluminum Motor Heat Sink
• Aluminum Cone & Dust Cap for Added Heat Dissipation and Strength
• High-Roll Surround for Added Cone Surface Area & Xmax
• Dual Mirror Stacked Spiders w/ Integrated Tinsel Leads
• Secondary Stamped Steel Basket for Easy Re-coning (not included)
lado esquerdo de 12 lado direito de 15
T/S Specs R1-12 R1-15
Fs (hz) 21.50 23.70
Qms 9.210 13.400
Vas (ft³) 2.863 4.825
Cms (mm/n) 0.220 0.140
Mms (g) 249.5 317.2
Rms (kg/s) 3.654 3.520
Xmax (mm) 12.70 12.70
Xmech (mm) 23.40 23.40
Dia (in²) 10.030 12.790
Sd (in²) 79.16 127.70
Vd (ft³) 0.042 0.068
Qes 0.490 0.650
Re (Ohm) 6.80 6.80
Z (Ohm) 8 8
BL (Gauss) 21.60 22.16
Pe (watts) 800 900
Qts 0.418 0.620
NO 0.159 0.265
1w/1m SPL (dB) 84.15 86.40
2.8v SPL (dB) 84.85 87.09
VC Dia. (in) 3.0 3.0
Impedance (Ohm) DVC 4 DVC 4
M-vd (ft³) 0.1500 0.2000
Measurements (in) R1-12 R1-15
Overall Diameter 12.75 15.625
Overall Height 8.625 9.875
Mounting Depth 7.375 8.625
Cutout Diameter 11 14
Motor Diameter 10.5 10.5
Motor Height 5.875 5.875
Flange Width 0.75 0.75
Flange Height 0.875 0.875
Sealed Box R1-12 R1-15
Min. Sealed (ft³) 1.00 1.50
Qtc 0.690 0.870
F3 (Hz) 42.70 41.40
Opt. Sealed (ft³) 1.50 2.00
Qtc 0.610 0.800
F3 (Hz) 40.90 38.70
Max. Sealed (ft³) 2.00 2.50
Qtc 0.570 0.750
F3 (Hz) 40.20 37.30
Ported Box R1-12 R1-15
Min. Vented (ft³) 2.00 3.00
Port (dia. x length) 4x14.5 (2)3x9.5
Fb (Hz) 34.10 34.20
F3 (Hz) 28.90 30.20
Opt. Vented (ft³) 3.00 4.00
Port (dia. x length) (2)3x11 (2)4x15.5
Fb (Hz) 32.20 32.00
F3 (Hz) 26.00 27.30
Max. Vented (ft³) 4.00 5.00
Port (dia. x length) (2)4x17.5 (2)4x16.5
Fb (Hz) 30.50 27.70
F3 (Hz) 24.50 23.80
Editado por Drifitking
caraio mas seu tópico tá sem graça mesmo em ?
Coloca mais conteúdo né mano ... por isso ninguém respondeu aqui rsrsrs !
e verdade esta mesmo vou tentar melhorar rsrs
pq ta pensando em trocar? o 3001 não tem uma musicalidade boa como falaram?
nao me agradou muito.. muitos vão falar mais eu ainda acho que os e2k de 15 tocavam melhor !!! rsrs
o problema é um só ... Falta GRAVE e sobra SUBGRAVE !!! rsrsrs
Eu precisandod e Sub grave e o cara querendo GRAVE rsrsrs ai ai viu rs !
olha que esta tocando muito subrave pena ele nao subir um pouco mais...... qualquer dia eu passo la na sua rua com o som ligado !!!! auhauhaha
caraca então é um sub bem do jeito que eu gosto, mais tem uma pegada de spl boa junto ao subgrave?
pelo oq intendi vc vai trocar pq ele não sobe muito?
de 25 hz ate uns 40 hz vai bem depois ta osso !!! melhor que isso so mexendo no duto pra ver no que da...... ou na caixa !!!
se não fosse um sub tão caro , caberia fácil no meu sistema ... mas é DEMAIS pra meu bolso ... sem falar que precisaria de somente 1
ja esta negociado o sub provavelmente chegue pra min na sexta feira que vem !!!! agora e correr pra trocar o modulo !!!!
Cara, esse Soundstream é quase um sonho pra mim, pena eu também não ter Cash$$$$ pra bancar uma criança dessas.
Mas há boatos de que esse sub é o CAPETA, tem subgrave e spl nervouss!!! sem contar a qualidade né. Tipo, ele é praticamente o sub TOP da Soundstream....chaaato né ?!?!?!
Acho que tu vai curtir e MUITO o resultado do bixano....
Flw, boa sorte e posta VIDEOS hein !! =D
PS: PUTA QUER PARIU DE CARRIOLINHA.....QUE SUB LINDO ESSE SOUNDSTREAM hein mano ?!?!? vai toma no meio do anus viu!
Só 12mm de xmax o R1??
Meu conhecimento de parâmetros é quase NULO, mas pra um subão desses 12mm não é mto pouco? Até o pioneer 3001 tem mais rs.
Gente essa sensibilidade dos 3001 ta errada !
no site e no manual diz 89 db's
eu tambem nao entendo nada mais esse xmax da meio estranho.... rsrs eu tirei esse parametros do site
Quero só ver esse sub tocando num 2K5D....deve ficar muito forte...
só por curiosidade e desculpe minha ignorância....
Xmax (mm) 12.70
Xmech (mm) 23.40
O que seria esse: Xmech (mm) 23.40???
Este é um subwoofer de SQPL.
O xmax de 12mm é bem compreensível.
Ele tem outros belos parâmetros a serem vistos..
Aprendam mais sobre eles aqui
Xmax (mm) 12.70
Xmech (mm) 23.40
Limite Mecânico..
Passar disso com certeza danificará o falante.
Aposto que esse sub com Xmax de "apenas" 12mm faz MELHOR e mais BONITO que muito "sub" com Xmax maior por ae !!! :rolleyes:
tem sub nacional com x-max de 17mm.. mas.....
Olha so.. to com dois 3001 aqui em casa...
vo fazer uma caixa pra eles este FDS...
OpO
sobre os 3001.. no aguardo do seu projeto.. esse falante me interessa muito!
Sobre o o soundstream.. duvido que não vá gostar desse falante..
apesar que olhando os parâmetros.. gostei mais do de 12"
Onde vc arranjou esse drift?
Editado por gino
OpO
estou em negociaçao com o user damiel
