Marcus DT
[DÚVIDA - Amp] Alpine MRP-F600 x Kicker 08ZX650.4
Estou começando a juntar $$ pra remontar o som que me furtaram, já comprei o sub UXP 12 D2, agora falta o módulo.
Estou em dúvida entre:
Alpine MRP-F600 (4 Channel Class A/B Power Amplifier):
- CEA-2006 Power Rating @ 4-Ohm: 100W x 4
- S/N 80dBA
- RMS Power @ 4 ohms: 100W x 4 (1% THD)
- RMS Power @ 2 ohms: 150W x 4
- RMS Power Brigded @ 4 ohms: 300W x 2
- Continuously Adjustable Gain Control
- Dual Sided Glass Epoxy PC Board
- Non-Fading Pre-Amp Output
- Discrete Pre-Amp Stage
- Gold Plated Input, Output, Power and Speaker Terminals Connector
- Adjustable Low-Pass/High-Pass Crossover
- Speaker Level Inputs
- Gold Plated RCA Input Connectors
- Top Mounted Blue LED Power Indicator
- Over-Current, Over-Voltage and Thermal Protection
- STAR Board Circuitry
- MOSFET Power Supply
- Thermal Management Control
- 4/3/2 Channel Design
Kicker 08ZX650.4 (4 Channel 650W Class A/B Car Amplifier)
- RMS Power @ 4 Ohms: 120W x 4
- RMS Power @ 2 Ohms: 170W x 4
- RMS Power Bridged @ 4 Ohms: 325W x 2
- MOSFET power supply
- Wired remote bass level control included
- LED power and protection indicators
- Tuned Bass EQ (0-18 dB bass boost at 40 Hz)
- Balanced differential inputs make KICKER ZX Amplifiers compatible with any factory radios
- Eliminates unwanted noise in a system
- Boost, gain, and crossover frequencies are top-mounted for easy access, and a handy protection indicator featuring a new flashing yellow low-voltage light enhances the end panel
- Bridgeable operation
- Speaker-level inputs compatible (switchable) through RCA connection
- Automatic turn on modes: remote, DC offset, or signal sense
- Thermal, voltage, and short circuit protection circuitry
- Variable high-pass filter (50-200 Hz, 12 dB/octave)
- Variable low-pass filter (50-200 Hz, 12 dB/octave)
- CEA-2006 compliant amplifier
- Frequency response: 20-20000 Hz
Já tive um Alpine MRP-F550 (o antecessor desse aí), gostei muito do amp... mas estou aberto a mudanças.
Além desse Kicker (que nunca escutei), quais outros amps nessa faixa de potência e preço que vocês acham que vá empurrar bem um UXP mais o kit 2 vias? E entre esses dois, com qual vcs ficariam?
Valeu,
Marcus DT
Qto vc pretende gastar no módulo?
O player sim faz muita diferença.
Cara, meu player acho que dá conta pro que eu to querendo.... é antigo mas tem o necessário para tocar bem um único amplficador (RCAs, voltagem, controles, etc).
Quanto ao custo do amp, no máximo 500 reais.
Valeu,
Marcus DT
Por 500 reais vc não consegue comprar o Alpine.
O Kicker acho q se tiver no PY é tb mais caro.
O Alpine custa 239 dolares, o Kicker 274 dolares. Também fiquei interessado pelo Clarion APX4361 (220 dolares).
E aí, Alpine, Kicker ou Clarion? O brigde de cada um, respectivamente: 300, 325 e 320w rms.
Valeu,
Marcus DT
