pedromsf
    8
Tudo que pedromsf postou
  1. Vendo subwoofer pouco usado em perfeito estado Segue auto falante com embalagem. Continuous Power Handling (RMS) 500 W Recommended Amplifier Power (RMS) 150- 500 W Nominal Impedance (Znom) 2 O Free Air Resonance (Fs) 32.97 Hz Electrical ?Q? (Qes) 0.533 Mechanical ?Q? (Qms) 7.027 Total Speaker ?Q? (Qts) 0.495 Equivalent Compliance (Vas) 1.136 cu ft / 32.17 L One-Way Linear Excursion (Xmax)* 0.550 in / 14.0 mm Reference Efficiency (no) 0.21% Efficiency (1 W / 1 m)** 85.37 dB SPL Effective Piston Area (Sd) 53.475 sq in / 0.0345 sq m DC Resistance (Re) 1.70 O http://produto.mercadolivre.com.br/MLB-814061736-subwoofer-jl-audio-10w3v3-2-ohms-_JM VALOR: R$ 900,00
  2. Vendo amplificador pouco usado em perfeito estado Segue manual, acessórios, ferramentas, caixa, plasticos. Onyx Series 5-Channel Class D Car Amplifier Channel 1-4 Max Power Rating: 4 ohms: 75 watts x 4 chan. 2 ohms: 150 watts x 4 chan. Subwoofer Channel Max Power Rating: 4 ohms: 350 watts x 1 chan. 2 ohms: 500 watts x 1 chan. Max power output: 1100 watts total FLUID-FETS MOSFET Circuit maximizing power efficiency while improving sound quality LED power (green) and protect (red) indicators Variable BassEQ Boost (0 to +12 dB bass boost fixed at 45 Hz) Built-in system diagnostics Mono channel operation Preamp RCA outputs to daisy chain multiple amps 3-way protection circuitry (thermal, overload, and speaker short protection) Heavy duty Black Onyx aluminum alloy heat-sink with illuminated MB Quart design Input sensitivity: Level: 200mV-6V 2 gauge power and ground wiring is required for installation. Contact us for information regarding a discount on select amplifier kits from our website when purchased together with this amplifier. Dimensions: 9-7/16"W x 16"D x 2-1/4"H http://produto.mercadolivre.com.br/MLB-814058144-amplificador-mb-quart-oa-11005-canais-_JM VALOR: R$ 1.000,00
  3. E quanto vai custar esse som? tem algum site que eu possa dar uma pesquisada, fazer orçamento? site de confiança?
  4. Beleza, então 2x woofers 12', 2x drivers e 2x super tweeter ficaria um bom som? 2x - Woofer Selenium 12" 12PW3 200W RMS 4 Ohms 2x - Driver Hinor HDI300 60W 2x - Super Tweeter Selenium ST304 40W Não quero montar um som para fazer festa, só para tocar no churras fim de semana, na praia. Nada muito top, mas que seja bom e se tiver um bom custo/beneficio melhor ainda!
  5. Cara, dei uma pesquisada, em outros fóruns e aqui mesmo, e não entendi por que tantos subs. Por que?
  6. Olá, tenho uma saveiro g3 ano 2000, comprei ela a pouco tempo e pretendo fazer uma caixa para instalar na caçamba. Entendo quase nada de som, muito menos automotivo, então resolvi me cadastrar e tirar minhas duvidas. Minha ideia é usar essa caixa como um auxiliar, já que durante a semana uso ela para trabalhar, pensei em algo que fosse facilmente removível. Pensei em por nesta caixa os seguintes itens: - (x2) Tweeter Selenium ST304 40W - (x2) Subwoofer Pionner 10" TW-S258D4 350W - (x4) Cornetas com driver Hinor HDI300 60W Outra dúvida seria de qual módulo usar, qual vocês recomendariam para essa caixa? Essa caixa ficaria com um som melhor, selada ou dutada? As medidas da caixa seriam: 1,30m, 0,40m, 0,35m (L, A, P) Agradeço desde já, espero resposta.
