larrycarvalho
    26
Tudo que larrycarvalho postou
  1. LINKS EDITADOS LINKS EDITADOS LINKS EDITADOS LINKS EDITADOS LINKS EDITADOS LINKS EDITADOS qual desses subs tem uma melhor qualidade ? ou qual marca teria melhor qualidade tou com duvida mais entre boss e alphalink o que acham ? http://www.onlinecarstereo.com/CarAudio/assets/ProductImages/Alphasonik_PSW812E.jpg General Features: Cast Aluminum CNC Machine Finished Alpha Basket Motor Assembly Heat Sink Kevlar-Reinforced Cone TLTF J-Surround High Tinsel Strength Two-Layer Surround Exclusive Mounting Ring Flat Progressive Rate Nomex Damper w/ Spiral-Woven Leads 8-gauge Lug-Lock Input & Output Terminals TLTF J-Surround Rated at 900 Watts RMS 92dB Efficiency Frequency Response of 28Hz to 500Hz 135 oz. Double-Stacked Magnet Dual 4-ohm 2-1/2" Voice Coils Mounting Dimensions: Depth: 6 5/8" (168mm) Through Hole: 10 7/8" (276mm) Diameter: 12 5/16" (313mm) Subwoofers are usually sold as a single unit unless otherwise noted. Authorized Internet Dealer Warranty: 1 Year Manufacturer warranty. http://www.onlinecarstereo.com/CarAudio/assets/ProductImages/BossAudio_CW125DVC.jpg Sensitivity: 96 dB RMS Power Range : 1200 Watts Peak Power Handling: 2400 Watts Impedance: 4 Ohm Frequency response: 25-1000 Hz Diameter: 15 Inch http://www.onlinecarstereo.com/CarAudio/assets/ProductImages/BossAudio_CW127DVC.jpg Power Peak: 2400W RMS: 1200W Cone Material: Non Press Cone Voice Coil Size and Type: 2.5" Efficiency 1 Watt/1 Meter: 95dB Frequency Response: 25-1.5000khz Impedance: dual 4 ohm Mounting Depth: 7-1/8" Subwoofers are usually sold as a single unit unless otherwise noted. Authorized Internet Dealer Warranty: 1 Year Manufacturer warranty. http://www.onlinecarstereo.com/CarAudio/assets/ProductImages/BossAudio_LAC129D.jpg Sensitivity: 96 dB RMS Power Range : 900 Watts Peak Power Handling: 1800 Watts Impedance: Dual 4 Ohm Low Frequency response: 25 Hz High Frequency Response: 2200 Hz Diameter: 12 Inch http://www.onlinecarstereo.com/CarAudio/assets/ProductImages/BossAudio_L12.jpg Sensitivity: 96 dB RMS Power Range : 1000 Watts Peak Power Handling: 2000 Watts Impedance: 4 Ohm Low Frequency response: 25 Hz High Frequency Response: 2200 Hz Diameter: 12 Inch http://www.onlinecarstereo.com/CarAudio/assets/ProductImages/Boss_Audio_P128DC.jpg Sensitivity: 96 dB RMS Power Range : 1200 Watts Peak Power Handling: 2400 Watts Impedance: 4 Ohm Frequency response: 25-15000 Hz Diameter: 12 Inch
