°ŦФЯЭŦФ°
    94
Tudo que °ŦФЯЭŦФ° postou
  1. BOM MEUS AMIGOS EU ESTAVA PENSANDO EM USAR ESSE T2.7 PARA EMPURRAR OS PROTECH E OS PW3 O T400 É PARA OS DRIVERS E TWEETERS
  2. ALGUEM PRA ME AJUDAR AI ...POR FAVOR
  3. BOM GALERA EU TAVA PENSANDO EM FAZER UM TRIO COM WOOFER NO MEU CARRO MAIS COMO JA TENHO UM PAREDÃO NA MINHA PICK UP CORSA PREFERI FAZER UM TRIO COM SUBWOOFER...MEU PROJETO É MAIS OU MENOS ASSIM: 2 Subwoofer Protech Sub600 15pol. 600wrms 4ohms = 4 Woofer Selenium PW3 8pol. 125wrms 4ohms = 1 Modulo Potencia Taramps T400 400X4D = 1 Modulo Potencia Taramps T2700 2700wrms = 2 Driver Selenium D200 50wrms = 2 Super Tweeter Selenium ST200 70wrms = 2 Kit 2 Vias Selenium 52V2A 5pol. 100wrms ( Par ) = MINHA DUVIDA É SE ESSE PROJETO VAI TOCAR BEM? SE OS MODULOS ESTÃO DE ACORDO COM OS FALANTES? E QUE BATERIA USAR E QUANTAS ? DESDE JÁ AGRADEÇO A AJUDA
  4. ENTÃO COMO JA TENHO ESSES PRODUTOS POIS GANHEI DE PRESENTE A MINHA DUVIDA É SE ESSE MODULO CASA A IMPEDANCIA CERTINHO COM A DO SUBWOOFER A MINHA DUVIDA É SOMENTE ESSA?
  5. AH ISSO MESMO AMIGO SOU DO YAHOO RESPOSTA MAIS QUEM FEZ ESSA PERGUNTA FOI MEU IRMÃO QUE USA MINHA CONTA É QUE EU NÃO TAVA AQUI ESSES DIAS E ELE TA FAZENDO UM SONZINHO NO FUSCA DELE COMO NÃO CONSEGUIA FALAR COMIGO EU INDIQUEI ESSE SITE QUE É CONFIAVEL PRA ELE FAZER PERGUNTAS E VC É DO YAHOO RESPOSTA TBM?
  6. BOM MAIS VAI CASAR CERTINHO A IMPEDANCIA? PQ DIZEM QUE ESSE MODULO MANDA 2 X 100W 1 X 400W
  7. OLA GALERA EU TO COM UM PROJETINHO BEM BASICO PARA FAZER NUM FUSCA E GOSTARIA DE SABER SE ESSE PROJETO VAI FICAR BOM E SE ESSE MODULO EMPURRA ESSE SUBWOOFER 1 Subwoofer Spyder Usina 12pol. 350wrms 2x4ohms 1 Modulo Potencia Megacharge 600wrms 3 Canais 1 Falante 6x9 H. Buster QB-6936 110wrms 4ohms ( Par ) DESDE JA AGRADEÇO
  8. ENTÃO GALERA PRA VCS ENTÃO É SÓ TROCAR AS D250 PO D200 E COLOCA PW3 10 POL. NO LUGAR DAS TRIO DE 12 AS BATERIA ESTÃO LEGAIS OU PRECISA DE 1 DE 150 OU ATE 2 FALTA MAIS ALGUMA COISA OBRIGADO PELA AJUDA E DESCULPA O TRANSTORNO
  9. SERÁ QUE É UTIL MESMO ESSES WOOFER DE 12 OU É MELHOR DEIXAR ELE PARA AJUDAR NOS MEDIOS GRAVES?
  10. MUITO OBRIGADO MEU AMIGO...ENTÃO O QUE EU PRECISO FAZER É SÓ TROCAR AS BATERIA TEM ALGO MAUS QUE POSSO ESTAR FAZENDO OU ESTA OTIMO ASSIM? ME AJUDEM AI GALERA
  11. OLA GALERA BOM SOU NOVO NO SITE E GOSTARIA DA OPINIÕES DE VCS SOBRE O MEU PROJETO 2 Subwoofer Protech Sub 600wrms 15pol. = 640,00 2 Woofer Protech Trio 350wrms 12pol. = 320,00 1 Modulo Potencia Taramps T2000wrms = 929,00 1 Modulo Potencia Taramps T1200wrms = 799,00 1 Modulo Potencia Taramps T400X4D = 439,00 2 Driver Selenium D-250X + Cornetas = 179,00 2 Super Tweeter Selenium ST350 = 198,00 2 Bateria Impact 90Amp = 618,00 GOSTARIA DE SABER SE TA FALTANDO ALGO ? SE ESSE PROJETO VAI FICAR BOM? DESDE JA AGRADEÇO
  12. UÉ ENTÃO ESSE PROJETO AQUI OS MODULOS ESTÃO ERRADOS? 2 Woofer Eros E415L 15pol. 500wrms 1 Modulo Soundigital SD1000.1D 2 Woofer Eros E-10 EP 10pol. 150wrms 2 Driver Eros ETD44 50WRMS 2 Super Tweeter Eros EFT 100wrms 1 Modulo Soundigital SD500.4AB 1 Bateria Impact 150 Amp BOM PEL OQUE ME FALARAM O SD1000 TOCA OS WOOFER E O SD500 TOCA O MEDIO + DRIVER E TWEETERS BOM FORAM QUE ME FALARAM NÉ
  13. MUITO OBRIGADO PELA AJUDA AMIGOS MAIS EU TENHO UM PRIMO QUE ESTA COLOCANDO ESSE SET NO CARRO DELE...MAIS ELE TEM DUVIDA SOBRE OS MODULOS...SERA QUE VCS PODE AJUDAR ELE 2 Woofer Eros E415L 15pol. 500wrms 2 Woofer Eros E-10 EP 10pol. 150wrmS 2 Driver Eros ETD44 50WRMS 2 Super Tweeter Eros EFT 100wrms VALEWW
  14. GOSTARIA DA AJUDA DE VCS ESTOU QUERENDO FAZER ESSE PROJETO AQUI SERA QUE VAI FICAR BOM? ESSE MODULO CONSEGUE EMPURRAR OS 2 STREET BASS? 2 Subwoofer Selenium Street Bass 15pol. 300wrms 2 Driver Selenium D200 50wrms 2 Super Tweeter Selenium ST200 70wrm 1 Falantes 6x9 Selenium ( Par )= 112,00 1 Modulo Potencia Soundigital SD500.4AB 1 Modulo Potencia Hurricane 4.120 1 Bateria Impact 90Amp ABRAÇO
  15. OLA AMIGO BOM TENHO UMA MONTANA E MEU SET É ESSE AI 4 Woofer Eros E-818 SDS 15pol. 800wrms = 3356,00 2 Woofer Eros E-312 LC 12pol. 350wrms = 538,00 2 Modulo Soundigital SD2300.1D = 2218,00 2 Modulo Soundigital SD500.4AB = 1258,00 4 Driver Eros ETD44 – 50wrms = 876,00 4 Super Tweeter Eros EFT – 100wrms = 404,00 1 Kit 2 Vias Selenium 6pol. 120wrms = 125,00 2 Mid Bass Selenium 6pol. 140wrms = 79,00 2 Bateria Impact 150 Amp = 1118,00 E POSSO TE FALAR QUE EROS É SHOW DE BOLA ABRAÇO
  16. OLA CAROL SEI QUE VC NÃO QUER PASSAR DE 250WRMS MAIS EU ACHARIA VC FAZER UM SOM QUE PELO MENOS FICARIA PELA VIDA TODA UM EXEMPLO É O SO QUE TINHA NA MINHA MONTANA FIZ UM SOM APENAS DENTRO DO CARRO NADA DE SOM NA CAÇAMBA TINHA: 1 STREET BASS DE 12 1 KIT 2 VIAS 1 PAR DE MID BASS SO QUE NÃO FIQUEI SATISFEITO E RESOLVI FAZER ESSE PROJETO 4 Woofer Eros E-818 SDS 15pol. 800wrms = 3356,00 2 Woofer Eros E-312 LC 12pol. 350wrms = 538,00 2 Modulo Soundigital SD2300.1D = 2218,00 2 Modulo Soundigital SD500.4AB = 1258,00 4 Driver Eros ETD44 – 50wrms = 876,00 4 Super Tweeter Eros EFT – 100wrms = 404,00 1 Kit 2 Vias Selenium 6pol. 120wrms = 125,00 2 Mid Bass Selenium 6pol. 140wrms = 79,00 2 Bateria Impact 150 Amp = 1118,00 AGORA SIM ESTA MUITO MELHOR SOM PARA A VIDA TODA POSSO TE FALAR QUE NÃO TEM MELHOR QUE A EROS AINDA MAIS ESSE WOOFER AI ANIMAL ABRAÇO
  17. AGORA...SERA QUE ESSE SOM VAI FICA BOM? VAI TER UMA POTENCIA BOA? QUALIDADE? O QUE VC POSSAM ME DIZER SOBRE MEU PROJETO E O QUE DEVO MUDAR NELE
  18. ISSO AI MESMO MEUS AMIGOS EU JA TENHO TUDO ISSO SIM SO NÃO SABIA SE ESSE MODULO TOCAVA MEDIOS MAIS OS AGUDOS MAIS MUITO OBRIGADO PELA AJUDA DE VCS ABRAÇO
  19. BOM MEUS AMIGOS GOSTARIA DA AJUDA DE VCS TENHO ESSE SET NO MEU FIESTINHA 95 E ESTOU EM DUVIDA SE ESSES MODULO VÃO TOCAR TUDO ISSO COM POTENCIA MAXIMA E QUALIDADE... 2 Woofer Eros E415L 15pol. 500wrms 1 Modulo Soundigital SD1000.1D 2 Woofer Eros E-10 EP 10pol. 150wrms 2 Driver Eros ETD44 50WRMS 2 Super Tweeter Eros EFT 100wrms 1 Modulo Soundigital SD500.4AB 1 Bateria Impact 90Amp A MINHA DUVIDA MAIOR É SE ESSE SOUNDIGITAL SD500.4AB ELE TOCA DRIVES + CORNETAS + MEDIOS ESPERO QUE VC POSSAM TIRAR MINHA DUVIDA DESDE JA AGRADEÇO A TODOS
