brou
Novo Projeto - Gol 1994 (Quadrado)
Olá, pessoal.
Postei há uns dias minha idéia para o som do meu carro, que seria composto por (HU, 2 Vias na frente, 6x9 Atrás, Módulo 5 canais e Subwoofer 10").
Após uma pesquisa no fórum, resolvi alterar este projeto para um de mais qualidade. Queria a opinião de vocês.
1) Pioneer DEH-P7400HD CD Receiver
Technical Details
Full Dot LCD Display (192 x 48 pixels, 3-line)
Built-In MOSFET 50W x 4 Amplifier
3 Sets of Hi-Volt RCA Preouts (4V) for System Expansion
5-Band Graphic Equalizer
Advanced Sound Retriever
2) JL Audio JX360/2 Class A/B Two-Channel Full-Range Amplifier
Technical Details
Rated Power 14.4 V Stereo: 110W x 2 @ 4 ohm // 180W x 2 @ 2 ohm // Rated Power 14.4 V Bridged: 360W x 1 @ 4 ohm
Rated Power 12.5 V Stereo: 90W RMS x 2 @ 4 ohms // 140W RMS x 2 @ 2 ohms // Rated Power 12.5 V Bridged: 280W RMS x 1 @ 4 ohms
THD at Rated Power: 1% @ 4 ohms // Frequency Response: 20 Hz - 20 kHz +/- 1 dB
Input Range: 200mV - 4V (Low-Level) // 2V - 10V (High-Level)
On-board Crossover: 12dB/octave High-Pass or Low-Pass with continuously variable cutoff frequency selection from 50 - 200 Hz. Defeatable.
3) Focal Access 165 A3 6.5-Inch 3-Way Component Speaker Kit
Technical Details
6.5-inch three-way component kit with woofer, tweeter, midrange driver, separate crossover
160 Watts maximum power handling with 4-ohm impedance
Woofers and midrange driver feature woven glass fiber cone and butyl rubber surround
Aluminum inverted dome tweeters for wide soundstage and accurate image
12/12dB/octave (300Hz-4kHz) crossovers with 3-level tweeter control
4) JX250/1 - JL Audio Monoblock 250W RMS 500W Class A/B Amplifier
31%2BOrac9vsL._SL500_AA300_.jpg<p>
Technical Details
3-Way System Protection circuitry (thermal, low impedance, and speaker short protection)
Heavy duty aluminum alloy heatsink for effective heat dissipation
Nickel-plated RCA level inputs
Nickel-plated screw terminals
Dimensions: 11L x 7-3/4"W x 2-1/8"H
5) JL Audio 10W0v3-4 10" W0v3-Series 4-Ohm Car Subwoofer
Technical Details
10" W0v3 Series Subwoofer
High Excursion for Louder Bass, Less Distortion
Power Handling: 60-300W RMS
Nominal Impedance: 4 ohm
Efficiency (1W/1m): 84.07 dB SPL
Bom, essa é a idéia que eu tive. Futuramente, penso em colocar um Kit Coaxial na traseira, ligada diretamente no player, só para tocar as músicas na parte traseira, não alterando o palco sonoro (pelo menos foi isso que encontrei por aqui hehe).
Qual a opinião de vocês? Sobre o HU, Amplificadores, Alto-Falantes?
Obrigado.
Abraços.
Editado por brou
Falando em preços fica mais facil de dizer se vale ou nao a pena
Fala, Scult. Tudo bom? Vou listar os preços:
1) Player Pioneer - $135
2) Kit 3 Vias Focal - $340
3) Módulo 2 Canais JL Audio - $120
4) Módulo Mono JL Audio - $120
5) Subwoofer JL Audio 10" - $80
Total: Aproximadamente $800 (Sem contar os cabos RCA, de força, etc, que acredito que acrescente uns $80 no preço). Então o valor total fica aproximadamente R$ 1800 reais.
Abraço.
Editado por brou
Esses valores são tipo, CERTEZA ABSOLUTA? sem chance de serem taxados em 60% em cima? Se for, o preço está legal sim.
Mas eu mudaria os amplificadores. JL pra mim é Subwoofer. Comprando um Arc Audio, pode ser até os Minis, acredito que fique poouca coisa acima disso, e com uma otima potencia. Eu daria preferencia para um amplificador 4 canais e um mono, pois assim voce pode pelo menos colocar o kit amplificando os midbass separados em um par de canais e os midranges+tweeters em outro par de canais.
Os valores são certeza sim pois as coisas não vão vir por correio. Um parente que vai trazer de fora.
Quando ao amplificador, colocando um de 4 canais eu não deixaria muito acima do que o kit suporta? Por exemplo, o kit é de 80 watts RMS de cada lado. Esse amplificador da JL manda 90W por canal a 4 ohms (12.5 V). Se dividir as partes e colocar um canal para cada, não fica muita potência para cada componente?
Qual outra marca posso utilizar? Não encontrei muitos Arc Audio no site.
Valeu! Abraço.
Abraço.
Eu tentaria fazer o seguinte:
Player, neste nível de som, já vai fazer falta um com TA. Força muito trazer um Alpine 117?
http://www.wooferset...connection.aspx
talvez alguém sugira algum mais barato, como algum JVC ou Kenwood, mas eu não conheço.
Amplificador, tem um muito bom, que vai ficar fácil pra quem vai trazer, pelo tamanho:
http://www.wooferset...-amplifier.aspx
De falantes acho que é por aí mesmo. Se vc gosta de um som bem aberto e presente, focal é a opção. Só se vc quiser mais suavidade, morel ou DLS seriam opções melhores.
De mais, procura uns bons cabos, tipo knuconcepts, e caprixa na instalação que tem tudo pra ficar muito bom.
Edit: Olha outr opção de player:
http://www.woofersetc.com/p-9869-kdc-x995-kenwood-excelon-in-dash-cd-receiver-with-bluetoothhd-radiopandora-control.aspx
Editado por R2_luciano
com o amplificador eu concordo totalmente! agora HU, eu sou adepto de Alpine, confesso. Mas esse player é a maior cagada que eles já fizeram.! não tem absolutamente nada nele. Tentaria.um Alpine 9887 então, que da pra tentar encontrar barato até aqui no Brasil mesmo.
Usado o leque aumenta bastante. Eu só quiz dizer que deve procurar um player com TA.
http://www.wooferset...ra-control.aspx
Boa noite, amigos. Tudo certo?
Vi as opções que vocês passaram. Achei meio salgado o preço do HU e do Amp também. Encontrei umas opções de HU com Time Alignment e um Amp da Arc Audio mais barato. Dêem suas opiniões, por favor.
Player: http://www.woofersetc.com/p-10680-mex-dv1700u-sony-in-dash-cddvdmp3-stereo-receiver-with-ipod-control-and-video-output.aspx
Amplificador: http://www.woofersetc.com/p-8218-kar-4004-arc-audio-4-channel-400-watt-amplifier.aspx
Não entendi quando o Luciano disse que a Focal tem um som mais presente e a DLS ou Morel, um som mais suave. O que seria um som presente, e um som suave?
Eu vi esse cara no Youtube e achei o som dele muito bom:
Queria algo mais ou menos assim no meu carro.
O que acham?
Abraços.
Eu recomendei aquele amp, pois além de bom, é pequeno e leve, muito mais fácil de trazer, não é obrigatório comprar amp Arc Audio.
tem algum mais em conta e bom que vc conheça? esse Arc Audio que postei, o que vc acha? é um 4 canais (4 x 50W a 4 ohms). a potencia do kit 3 vias é 80W cada lado. aí deram a idéia de eu ligar as partes separadamente no módulo, tipo Mid Bass em um canal e Mid Range + Tweeter em outro canal.
Esse é o Arc de entrada... Sei la, eu aproveitaria a oportunidade de trazer de fora e traria o outro Arc, o Mini ou o KS...
Se for pra comprar esse player, compraria aqui.
Eu entendo, mas não tenho banca pra pagar 750 reais em UM amplificador. Tenho 2 mil (no máximo, estourando) para bancar o som todo, com a instalação. Aí fica difícil comprar tudo do melhor, entende?
Ué, faz aos poucos, como grande parte do pessoal aqui do forum. Vai acabar algo que não é tão bom, vendendo em pouco tempo e perdendo dionheiro a toa.
Não precisa gastar todo a sua grana agora e comprar tudo. Quem faz isso, raramente se dá bem (só quando o nivel do investimento é pelo menos 4 vezes maior que o seu), então é melhor fazer bem feito do que fazer tudo de uma vez e ficar uma mer**, concorda?
Bom, comprei o Player. quase 200 reais mais caro do que eu esperava, mas foi o mais barato com a função Time Alignment. É este aqui: http://www.crutchfield.com/S-hWvbvvcIQzC/p_113KDCX996/Kenwood-Excelon-KDC-X996.html
Agora estou pesquisando Kit 3 Vias. Existem alguns da JL Audio (Modelo C5) e DLS (Reference 6.3). Já ouviu falar de algum desses?
E quanto ao amplificador, qual parâmetro eu devo analisar para saber se é bom? Como eu vou saber se ele atende a potência necessária pelos falantes?
Obrigado.
Amplificador é na base da leitura. Busca por opiniões e coisas do tipo. E a potência nem sempre é tudo /(apesar de eu procurar sempre colocar o dobro do rspecificado.)
Seguindo a lógica de um bom custo beneficio de equipamentos fora do país (U.S.A.), optaria pelo um set parecido com o meu (Kenwood KDC-x994 - Clarion APX-4361 - DLS R6A - JL Audio 10w1v2.4 - Knukonceptz):
* H.U. Kenwood KDC-X996 - U$ 225,00
http://www.ebay.com/itm/NEW-KENWOOD-KDC-X996-CD-MP3-WMA-BLUETOOTH-PANDORA-iPod-USB-CAR-RECEIVER-KDCX996-/270985021665?pt=Car_Audio_In_Dash_Receivers&hash=item3f17f748e1
* Kit 2 vias DLS R6A - U$ 200,00
http://www.ebay.com/itm/DLS-REFERENCE-R6A-SET-CAR-AUDIO-6-5-2-WAY-COMPONENT-SPEAKERS-120-WATTS-NEW-/130705429750?pt=Car_Speakers&hash=item1e6ea694f6
* Subwoofer JL Audio 10-W1V2.4 - U$ 110,00
http://www.woofersetc.com/p-2731-10w1v2-jl-audio-10-subwoofer.aspx
* Amplificador Clarion XH-5410- U$ 220,00
http://www.ebay.com/itm/Clarion-XH5410-680-Watt-4-3-2-Channel-Amplifier-/400142211218?pt=LH_DefaultDomain_0&hash=item5d2a559892
Total: U$ 755,00
O resto vc compra de bons cabos para a instalação Knukonceptz.
Assim , vc terá um som SQ bem acima da media na casa de 2 mil reais.
Editado por RBR
http://www.ebay.com/...=item3f17f748e1
http://www.ebay.com/...=item1e6ea694f6
http://www.wooferset...-subwoofer.aspx
http://www.ebay.com/...=item5d2a559892
Total: U$ 755,00
fala RBR, tudo certo?
po, gostei desse set seu, viu. é praticamente o que estou pensando em comprar. o player já comprei, é Kenwood KDC-X996. agora estou em dúvida com relação ao Kit de falantes. pego um Focal Access ou invisto em um 2 vias melhor?
Obrigado!
Total: U$ 755,00
:+1 , ta bacana o set, alem de que se resume a 1 amplificador so
acho um pouco mais pratico que usar 2, questao de fiação, e tals, consumo menor de bateria
e futuramente pode ate deixar ele para estereo apenas
Vc faz questão mesmo do 3 vias?
Eu acho difícil montar um 3 vias legal com seu orçamento. Não que não seja possível, mas eu desisti.
Já pensou em full+woofer? Dá pra economizar um pouco, inclusive.
Alguns fuljs que dispensam tweeters:
http://www.madisound...n-3-full-range/
http://www.madisound...a-3-full-range/
Alguns woofers para se pensar:
http://www.madisound...5-woofer-4-ohm/
http://www.madisound...idwoofer-4-ohm/
http://www.speakerci..._Code=DaytonRef
http://www.parts-exp...tnumber=295-305
É, o único kit que se encaixa no meu orçamento é o Focal Access. mas eu estou desistindo já, pois descobri que detesto tweeter com som metálico. Gosto de um agudo mais suave.
Esses falantes são bons? Eu teria que comprar um Crossover para o conjunto, não teria?
