Rhoxy
Boston Acoustic SPG 555
Olá a todos.
Este é o meu primeiro post.
Stou querendo dar um UpGrade nos meus subgraves e pesquisando encontrei este:
• Enclosure Type Ported
• Power Handling 1000W RMS
• Impedance 2-ohm
• Q-Tune Setting 34Hz @ 1.0
• Tuning Frequency 34Hz
• Height 13-1/4"
• Width 30-1/8"
• Top Depth 12-3/4"
• Bottom Depth 17-3/4"
• SPG555 Reference Standard Subwoofer
• MDF enclosure with a double wall front baffle, dadoed ends
• Factory tuned ported enclosure for optimum response from SPG555
• Integrated port maximizes surface area while adding structural rigidity
• Nickel plated heavy duty input terminals
• 2Ω for optimum power output from Boston GT amplifiers
Product Specifications:
• 13" Single 4 ohm SPG Series Oval Subwoofer
• Power Handling:RMS: 1000 watts
• Impedance: Single 4 Ohm
• Polypropylene cone woofer
• Foam woofer surround
• RadialVent® cooling directs airflow around the voice coil for increased power handling
• RVC™ (Removable Voice Coil) allows coil to be exchanged without removing the woofer from the enclosure
• SPS™ (Soft Part System) technology allows for cone assembly removal
• SPG555 can be field-stripped and custom painted, powder-coated, or plated for a custom look
Simplified mounting with the integral sealing gaskets
• 3-1/2" Voice coil
• 3-3/4" peak to peak excursion for devastatingly accurate, deep bass output from small sealed enclosures
• 555 cm2 of surface area
• Compatible with the SPG-TR passive radiator
• Frequency response: 20-350 Hz
• Sensitivity: 87.7dB
• Xmax: 22mm
• Mounting Depth: 8-1/4"
• Cutout Dimensions: 13-3/16" x 10-7/16"
• 1-year Manufacturer's warranty
Ele esta no site da Top's com um preço razoável
http://loja.acessorioautomotivo.com.br/loja/produto-99750-2310-subwoofer_555cm_boston_acoustic_spg_555__1000w_rms__promocao_relampago
O + interessante é a proposta da bobina tipo refil.
Qual seria a comparação com os MTX 12?
Estou tentado a comprar.
Alguem conhece?
Abç a todos.
O q + me chamou a atençao neste sub foi:
- desce muito (20Hz) e sobe muito (350Hz), nunca vi isso;
- bobina em forma de refil, e cone tbm, nunca vi;
- Xmax de 22mm;
- cone oval de 555cm2, isso corresponde a uma area de qual polegada?
- super leve;
- dá p instalar numa caixa praticamente do seu tamanho (opcionalmente, claro, ja vi nos carros dos gringos com caixa enorme).
Meu propósito é SQPL.
Aguardo comentários dos colegas entendidos.
E aí rafa, blz?
Vc achou caro? Td bem é caro, mas um EDX custa o mesmo e não tem estas vantagens q descrevi anteriormente.
E aí rafa, blz?
é que se eu fosse montar outro set agora eu não ia de edx ... ia de dd, shocker, kicker, etc...
esse meu set eu comprei antes de ser membro dessa comunidade ... os cara aqui odeia bravoxx edx ...kkkkk
E aí rafa, blz?
papel aceita tudo... creio eu que se vc quer um sub bem acabado com muita força...iria de t9 t2 o kicker e etc se tem dinheiro para pegar ve se consegue um orion hcca que é muito melhor....mas caso queira força bruta jah sabe as receitas shocker dd e etc...
Agradeço os comentários, todos eles são bem-vindos..., afinal stou aki pra isso mesmo..., aprender...
mas eu stava querendo ouvir comentarios de quem ja escutou.
Como é a qualidade de seu timbre?
A musicalidade?
Toca bem em baixas potencias?
Peca em que?
Se parece com qual sub da sua categoria?
Ja lí q a Boston tem boa fama na confecção de subs.
Tbm poderia ser de relatos dos proprietários gringos dos foruns do exterior. Ja fiz isso mas meu conhecimento de eletronica e da matéria em geral é limitado..., sendo assim, nao sou o cara certo para tal.
Eu vejo mtas vantagens nessa proposta de sub inovador: alem das citadas no meu post acima, tem nota fiscal, refil da bobina e cone e garantia numa loja conceituada de SP-SP. Eu mesmo ja comprei varios itens la e posso dizer q o tratamento é VIP. (nao sou dono/funcionario, nem ganho nada por isso, se fosse um lixo eu diria).
Sim..., o 555 corresponde a área do cone q é +/- um de 12'.
Nunca vi isso na minha vida.
A área dele corresponde a um subwoofer de 12" (540cm²).
É um tiro no escuro, tudo depende de você, se quer inovar, vai fundo, já se quer ficar no "mais do mesmo", tem vários tópicos...
Pois é Lucas..., eu tbm nunca vi isso. Estou empolgado.
Chamou-me muita a atençaõ os pontos positivos desse novo produto.
Eu estou até disposto em bancar a cobaia e fazer um projeto em cima dele e posteriormente expo-lo neste forum. Mas para tal precisaria de um minimo de informação de quem ja escutou e/ou me/nos indicasse um link dos comentarios gringos. So q tem um probleminha..., caso isso demore, posso perder o preço promocional e aí meu amigo..., adeus! O preço cheio dele é totalmente inviável, pelo menos pra mim.
Vc é um membro antigo, se kiser contribuir avisando nossos colegas + antigos a contribuirem, seria ótimo.
Abç
Blz amigo, poucos aqui ja ouviram um sub da boston, mas é uma marca muito boa e normalmente nao é barato se vc tem condiçoes de bancar o investimento e quer fazer o teste da uma pesquisada e ve se encontra alguma coisa nos foruns gringos la vc deve encontrar boas informaçoes sobre esse sub e a marca tb.
As linhas G3 e G5 são excelentes para um bom SQ. Este para um SQPL seria ideal, mas não esperem "barulheira" apenas igual os MTX, já que o propósito da Boston é bem diferente. Algum tempo atrás tava pensando em montar um set com um sub destes, só não segui com a ideia adiante, pois resolvi voltar com um antigo hobby...
Acho estes ovais muito exclusivos!!! Se tivesse $$$ faria o teste com estes subs nunca ouvi esta linha da Boston, mas como o Vinicius MB falou ...ouvi somente os subs das linhas mais leve para SQ e o timbre é muito bom.
Opa entao tenho um sub da boston de 8 (nada comparado a esse), o sub é otimo para SQ;
obs: nao se esqueça que a boston fechou;
abraço
att.
Ebert
Pode até ser bom ! + será que é tão bom assim a ponto de justificar 1.287,00 reais um sub de + ou - 12'' ???
Com essa quantia da pra trazer um belo de um sub do paraguaí em !
verdade podes trazer um t2 um 9512, 9515 kicker l715 l712, tudo esses monstros ae!!!
abraço
ebert, blz? Qual a fonte q vc recebeu a info q a Boston fechou? Ontem entrei no site e até me cadastrei na newslleter...??
Todas as opinões são válidas, agradeço a todos..., mas como prezo por SQPL, a intenção continua..., poderia até comprar um DD pela metade do preço, mas essa não é a proposta...
No momento estou atras dos valores (Vas, Qts, Qes) p fazer uma caixa, pois o site não informa. Quem tiver, pf, manda...
Achei os parametros do sub e aki vão eles p quem tiver em mente um projeto parecido:
General Specifications
Model: SPG555-4 / SPG555-2
Nominal SD: 555cm2 / 555cm2
RMS Power Handling: 1000w / 1000w
Impedance: 4Ω / 2Ω
Frequency Response (±3dB in car): 20-350Hz / 20-350Hz
Weight: 26 Lbs. / 26 Lbs.
SPG555 Thiele-Small Parameters
Fs (Hz): 31.90 / 29.68
Re (Ohms): 3.15 / 1.68
Qms: 11.66 / 11.70
Qes: 0.86 / 0.67
Qts: 0.80 / 0.63
Vas (Liters): 39.77 / 44.40
Mms (Grams): 276.7 / 286.20
Cms (μM/Newton): 89.9 / 99.9
Xmax (Mm): 22 / 22
Xmech (Mm): 49 / 49
Sd (CM 2): 555 / 555
Bl (Tesla-M): 14.27 / 11.58
SPL Eff (dB @ 1w/1m): 83.6 / 84.2
SPL Sen (dB @ 2.83v): 87.7 / 91.0
