SurfriderBR
Projeto Sq Para Stilo
Boa Tarde a todos,
Sou novo aqui no forum e gostaria da opinião de vocês sobre meu Set.
O Set pretendido é o seguinte:
O HU será o original do Stilo mesmo que se nao me engano é Visteon/Pioneer (preciso confirmar isso) e usarei um conversor RCA para ligar no Ampli.
Amplificador - Lightning Audio Strike S4.400.4
400 watts, 4-Channel Amplifier
RMS Power Output:
4 ohms: 50 watts x 4 channels
2 ohms: 100 watts x 4 channels
Bridged, 4 ohms: 200 watts x 2 channels
Power Fuse
Power Connector Terminals
High level Speaker inputs
RCA Input jacks
Level control
Crossover Filter Switch
Adjustable Crossover Frequency control
Remote level control
Speaker connections
Pass thru outputs
Subsonic control
Fuse rating: 30A x 2
Kit Componente 2 vias (portas dianteiras) - Lightning Audio Strike S6.65C
6-1/2" 2-way Component System
Power Handling:
Peak: 150 watts
RMS: 75 watts
Impedance: 4 ohms
Chrome Plated Custom Tooled Basket
Vacuum Formed Polypropylene Cone Coated w/ Custom Mixed Gray Metallic Paint
Butyl Rubber Surround
External 12dB/Octave Crossover
3 Position Tweeter Attenuation
1" Silk Dome Tweeter
Frequency Response: 55 Hz - 20 kHz
Sensitivity: 85 dB
Mounting depth: 2-1/2"
Subwoofer 10 - Lightning Audio Strike S4.10.4
10" Single 4 ohms Subwoofer
Power Handling:
Peak: 600 watts
RMS: 300 watts
Heavy Duty Chrome Plated Steel Basket
Double Stacked Motor Structure
2" 4-Layer Voice Coil
Injection Molded Polypropylene Cone
Complex Thermoplastic Elastomer Surround
Aluminum Voice Coil Former
Woven Tinsel Leads
X2 Spiders
Kapton Matrix Former
Flow Grate
Coaxiais (porta Traseira) - Lightning Audio Strike S4.65.3
100W Max, 3-way 6-1/2" Speakers
Power Handling:
Peak: 50 watts
RMS: 100 watts
Impedance: 4 ohms
Frequency Response: 60 Hz - 20 kHz
Sensitivity: 88 dB
Mounting depth: 2-3/8"
Procurei reviews sobre essa marca mas achei muito pouco na net, entao gostaria da opinião de vcs.
A idéia é ter um som de qualidade pra tocar p dentro sem gastar muito.
Todas sugestões serão bem vindas....
Obrigado
Boa Tarde a todos,
RMS Power Output:
Power Fuse
RCA Input jacks
Level control
Speaker connections
Pass thru outputs
Subsonic control
Power Handling:
Peak: 150 watts
RMS: 75 watts
Impedance: 4 ohms
Sensitivity: 85 dB
Power Handling:
Peak: 600 watts
RMS: 300 watts
Woven Tinsel Leads
X2 Spiders
Flow Grate
Power Handling:
Peak: 50 watts
RMS: 100 watts
Impedance: 4 ohms
Sensitivity: 88 dB
Obrigado
Ninguem?? :(
Vc pegou este orcamento em alguma loja????
Essa marca não é tudo isso para qualidade nao, ela é uma segunda linha da fosgate, creio que se vc usar produtos nacionais mesmo, como falantes e sub da nar, e partir para um modulo audiobank, wharf, blau, fosgate dos antigos etc etc fica um resultado ate mais satisfatorio e com um custo menor.
Eu peguei isso no site da soniceletronix.com
O orçamento dele vai sair em torno de 1000,00 tudo...como havia visto alguns projetos com alguns componentes da Lightning Audio, achei que seria bom para SQ..por isso que postei aqui para opniões dos colegas do forum..
Eu tenho aqui un RF Punch 200.4a mas não sei o que consigo empurrar com eles..
Agora estou vendo outro set com:
Subwoofer 8'' MB Quart RWE 204
8" Reference Series Subwoofer
RMS Power Handling: 150 watts
Dual 4 Ohms Impedance
Inverted Rubber Suround
Cast Alloy Basket
Treated Paper Cone with Parabolic Poly Dustcap
Kapton Former
Gold Binding Post Terminals
1-year Sonic Electronix warranty
Kit componente MB Quart RUA 216
6 1/2" 2-Way Component System
Woofers with extremely shallow plastic chassis for optimized installation in stock locations with limited mounting depths (only 1.65”)
Encapsulated, front-mounted neodymium magnet system
1” tweeters with titanium dome in plastic housing
Crossovers with variable two-level tweeter output
Power Handling: 50 watts - 120 watts @ 4 ohms
4 ohm Impedance
Crossover: 12dB per octave
Frequency Response: 38Hz - 32kHz
Sensitivity: 90dB
6 1/2" Polypropylene Woofers
German Engineering
E o amp queria usar apenas um para empurar tudo...(sugestões)
