Dimebag
Fiats Coupes
Ae galera.
Todos fortinhos e bonitinhos. :vts
ohn S' Fiat Coupe 20V Turbo - 460BHP, 431lbs/ft
One of the fastest Fiat Coupe 20V Turbos in the World, and the original 2.4 conversion
Engine:
Torque Italia 2.4 Conversion Shortblock
Modified Fiat Group 175A3 5cyl 2.0 Block
Flex-honed
Torque Italia designed forged pistons
Torque Italia designed forged steel rods
Torque Italia 2.4l nitride hardened long stroke crank
C&B 'Fast Road' 280/260 10.2in/9.6ex cams
Blitz C1 6" stainless steel mesh intake cone
polished aluminium 6"-4" intake trumpet
4" Straight through intake
Bosch Motorsport 550cc/min injectors
3" turbo downpipe
3" straight through exhaust with single back-box
6 Speed LE Gearbox
Bespoke GT30 Hybrid Turbo
A/R 0.70 T-04S Compressor cover with 4" intake and 2.5" exit
0.86 exhaust housing with GT25 exhaust flange
Bespoke matched compressor and turbine wheel combination
Internal wastegate
Torque Italia Stage 4 Head
Ported High Flow Cylinder head with redesigned intake and exhaust ports
New oversized valve seats
Custom enlarged intake valves
Custom enlarged hollow exhaust valves
3 angle valve seats
back-cut valves
Ported intake and exhaust manifolds
Skyline style Front-Mount Intercooler with 3" hoses
Intercooler water spray with 4x nozzles
Aquamist 2C system mapped to engine management
Dedra ancillary water bottle for intercooler water spray
Torque Italia oversize aluminium radiator
Pipercross Oil breather filter
Helix uprated clutch cover plate and alcon paddle clutch
HKS Super SQV (SSQV) VTA Dump valve
Styling
Cadamuro front splitter
Zender rear apron
LE side skirts
Torque Italia silver graphics
8x18" 5x98 ET35 Antera 183 Split-rim road alloys with Toyo 245/35R18 tyres
8x17 5x98 ET30 Azev E track alloys with Yokohama A048R 215/45R17 front and 225/45R17 rear tyres
Torque Italia polished rocker cover
Torque Italia polished plenum chamber
Torque Italia colour coded sparkplug cover
Dented bonnet (still!)
Suspension & Brakes
5x98 Alfa Hub conversion
Porsche 996 Twin Turbo [brembo] front monobloc aluminium calipers with custom caliper mounting brackets
Pagid blue fast road pads
Recalibrated brake compensation
340x35mm cast vented Porsche discs on alumium rotors
TI/FK Stainless coilover kit with uprated springs and shocks
Uprated front and rear anti-roll bars
Momo sport inverted strut brace
Interior
Dial rings, heater rings, clock ring
Pininfarina kick plates
Nomad twin A pillar guage pod
60mm 2.5 Bar SARD boost gauge
AEM wideband UEGO lambda sensor and gauge
SPA intake temp/EGT dual digital gauge
Torque Italia short-shift kit
Engine Management
Motec M600 ECU mapped by Mark Harrison at Owen Developments
Modified variator switchover
gear and rpm boost maps
Anti-lag launch control wired onto horns
Aquamist 2C map
Motec 3 bar MAP sensor
Motec air temp sensor
408BHP @ 1.25 bar on Optimax, 460BHP @ 1.25 bar on 76Racing RFT 102RON Race fuel
Mapped to 1.6 bar (no data presently)
Fuelling
Walbro 255lph high pressure fuel pump
Direct voltage feed
Mavric's Fiat Coupe 20V Turbo - 500BHP
The first and only 11s Coupe.
John Dean's 20V Turbo - 500BHP
Engine:
Flex-honed
Ramair Induction with Torque Italia Straight Induction mod
750cc/min injectors
Full 3" exhaust system
6 Speed LE Gearbox
Internal wastegate
Owen Developments 'Evo' GT25 Cast Turbo elbow
Torque Italia Stage 3 Head
Ported High Flow Cylinder head with redesigned inlet and exhaust ports
3 angle valve seats
back-cut valves
custom enlarged inlet valves
Evo-style Front-Mount Intercooler
Aquamist 1s system with ERL water level switch
Dedra ancillary water bottle for water injection
Torque Italia oversize radiator
Twin plate clutch rated at 650lbs/ft
Styling
Full Zender Body - front and rear bumper plus sideskirts and grille
7.5x18" 4x98 ET35 Wheelmania Jade Alloy wheels
Hella LED rear light conversion
Colour-coded sparkplug cover
Matt black exhaust manifold heatshield
Polished oil cap
Colour coded LE strut brace
Engine Management
Advanced Tuning Upgrade - launch control, anti-lag etc.
Advanced data logging
Bosch LSU wideband lambda sensor
Hall sensors for traction control
Adjustable slip traction control
460BHP on Optimax, 500BHP on race fuel
Fuelling
Walbro 255lph lift pump
External swirl pot
Bosch Motorsport '044' External fuel pump
Braided interconnects
Mike Davies' Fiat Coupe 20V Turbo - 340BHP and rising
Trackday special
Dubai Surprise!
Spec coming soon....
http://www.torqueitalia.com
PS: Retirado do fórum www.temprabr.com
Falowz.
Caraca, esses eu curti... AHSuHSUAHSHAShuaHS
Eu tb quero 1... HASuhAShAUshs
tudo manco....
AP da pau facil...huahuahuahuhuauhauha
que motor é esse 2.4?
originalmente é o 2.0 do tempra não é?
o que ta escrito ali é o 2.0 20v do marea que passou pra 2.4 ..só isso
toda mecanica de tipo 16v
só o motor desse que naum pq no brasil e o mesmo motor!!!
éééééé...
tá aí o motor AMADO pra mim da fiat /////
:mac1
:banghead huumtsa... além do meu AP eu tambem queria ter um marea com um motor desses coupé daí... :banghead
pra mim o ronco deles é mais munito que os 6 caneco...
huRrm... pistaozinhos sobe e desce de escadinha...
///// FIAT presença!
podi cre
abraço aí galera
mancos de respeito, realmente o ronco desses 5 cilindros são absurdos de lindo!
mas continuo achando o coupe mais feio que bater na mãe por causa de ovo frito
Fiat Lover! :rolleyes:
Realmente, daí vc ver que dá pra montar um carro desses pro dia-a-dia.... tendo como manter, eu rodaria diariamente num manco desses...
ah, o Ronco do 5 Cilindros com um escape de uns 2,5 é apaixonante... só ao vivo pra entender!
Rogério_MC
Meu sonho um coupé 20v T... ai sim eu iria me matar :vts
PQP 0.o
MUITO
SHOW
460cv com só 1.25bar de pressão... HAHAUHAEAHAH Vai, ap....... UHAUHAUh
Carros showwwwwwwwww
Abraços!!!
///// <- n. de barrinhas = n. de cilindros.
sem mais.
