Guigo1111
Vendo audison AV 5.1K zero na caixa
Zero na caixa completo! Nunca ligado!
V 5.1k, 1650 W (RMS) max, five-channels: with its hybrid design, it is the specialist amplifier for front + rear + subwoofer or multi-amplified front + subwoofer systems.
Its high-quality AB Class output stage provides two channels with 250 W (RMS), combined with another pair of A class pure audio channels rated at 75 W (RMS), perfect for active two-way front speaker systems. The D Class mono section provides 1000 W (RMS) for an efficiency and powerful subwoofer output. AMP (Amplifier Management Processor) constantly checks the operating status system and communicates with the user through 4 different coloured LEDs, located on the top panel; ART (Automatic Remote Turn On-Off) allows automatic turn-on/off when a remote signal isn’t available from the source.
AV 5.1k Tech Sheet
Power Output
Load Imp.5 Channels
4 Ohm75 W x 2 + 140 W x 2 + 600 W x 1
4/2 Ohm75 W x 2 + 140 W x 2 + 1000 W x 1
2/4 Ohm75 W x 2 + 250 W x 2 + 1000 W x 1
Valor R$ 6.700,00
Editado por Guigo1111
