Fabaum_ITB
[VENDO] dB Drive SPA 90.4
Specs
2 ohm stereo capability
Continuously variable 18dB boost on bass EQ
Continuously variable 12dB per octave high pass and low pass crossover
Direct-connect integrated speaker and power wire terminals
DC-DC PWM power supply
Bipolar outputs
Buffered pre-amp input circuitry
DriveSink heat management system
Power Specs:
Rated Power: 14.4 volts
4 x 90 watts @ 4 ohms
2 x 350 watts @ 4 ohms bridged
4 x175 watts @ 2 ohms
https://produto.mercadolivre.com.br/MLB-1160863287-modulo-amplificador-db-drive-spa-904-_JM
299,00 com frete incluso!
Visitante
