Cherubini
[VENDO] Ground Zero Reference
Amplificador Ground Zero Reference 4xs, Excelente detalhamento para quem procura um amplificador HI-FI.
Amplificador com todos os manuais, nunca reparado, funcionando 100%
Whats 11- 971289063
https://produto.mercadolivre.com.br/MLB-1054050304-amplificador-ground-zero-reference-4xs-_JM
Model
GZPA Reference 4XS
Type
4 Ch Class AB > A
Output Power @ 4 Ohm (CEA*)
4 x 120 W
Output Power @ 2 Ohm (CEA*)
4 x 220 W
Output Power @ 1 Ohm (CEA*)
Bridge mode @ 4 Ohm (CEA* / 10% THD)
2 x 500 W
Bridge mode @ 2 Ohm (CEA* / 10% THD)
Output power linkmode 2 Ohm
24 Volt Unit
18 Volt stable
Lowpass
40 - 3000 Hz
Highpass
40 - 3000 Hz
Bandpass
40 - 3000 Hz
Subsonic
Bassboost
Phaseshift
Adjustable Q-factor
Variable Bias Setting
Ja / Yes
Bass remote
High Level in
Line Out
Illumination
Weiße LED Innenbeleuchtung / white LED illumination
Dimensions cm / Inch
42 x 6,75 x 23,6 cm / 16.5" x 2.66" x 9.29"
Visitante
