Motta Slp
[VENDO] Rockford Fosgate Punch 225.2 e MB Quart PAB 4100
Amplificardor MB Quart Premium PAB 4100 4 canais R$ 600
Amplicador em bom estado sem as abas. Foi feito um pequeno reparo na chave manual de seleção de 2ch/4ch. Um terminal está com leve oxidação externa mas não interfere no funcionamento.
4-Channel Amplifier
Focused mass aluminium heat sink
RMS Power Rating:
4 ohms: 100 watts x 4 chan.
2 ohms: 150 watts x 4 chan.
Bridged, 4 ohms: 300 watts x 2 chan.
MOSFET power supply
Ultra-flexible and variable adjustable active crossover network
Vario bass equalizer circuit up to +18 dB
24 dB subsonic filter
Full range preamp outputs for easy daisy chaining of additional amplifiers
MB QUART-Logo with illuminated red rectangle
Wire concealing detachable end panels
Frequency Response (-3 dB) : 10 Hz - 30 kHz
Damping Factor: 200
Signal To Noise Ratio: >95 dB
THD: 0.05%
Channel Separation: >70 dB
Input Signal: 0.2 - 6.0 V
Crossover S/W: LP.BP/Full/HP
Variable Hi-pass / Subsonic Filter: 10 ~ 150 Hz
Variable Low-Pass (mono 24 dB): 30 ~ 150 Hz Full range
Bass Boost at 45 Hz: 1 ~ 9 dB
Dimensions: 18" L x 10.4" W x 2.25" H
Rockford Fosgate Punch 225.2 Old School Trans.ana (com abas). Vendido
Funcionamento 10/10
Aparencia 9/10
Ótimo estado de conservação. Quem conhece esse amplificador sabe a qualidade e força para tocar mono. Frete a combinar ou retirada em mão em jundiaí-sp.
Dynamic Power Rating (IHF-202 Standard) - Measured at 14.4 Volts
Mono into a 4Ω Load 690 Watts
Per channel into a 2Ω Load 345 Watts
Per channel into a 4Ω Load 220 Watts
Continuous Power Rating (Competition Standard) - Measured at 13.8 Battery Volts
RMS continuous power per channel from 20 to 20,000 Hz with less than 0.05% Total Harmonic Distortion (THD)
both channels driven into a 4Ω load 112.5 Watts
both channels driven into a 2Ω load 225 Watts
continuous power mono into a 4Ω load 450 Watts
Signal-to-Noise Ratio > 100dB A-weighted
Crossover Slope 12dB/octave Butterworth
Factory Default Crossover Frequency 80Hz adjustable (.047µf)
Frequency Response 20Hz to 20kHz±0.5dB
Bandwidth 10Hz to 200kHz±3dB
Damping Factor @ 4Ω (at output connector ) >200
Slew Rate 30 Volts µs
IM Distortion (IHF) <0.05%
Source Unit Compatibility (+15dB gain overlap) 17V max.
Input Sensitivity (+0dB gain overlap) Variable from 150mV to 3V
Protection NOMAD - Internal analog-computer output protection circuitry limits power in case of overload. Thermal switch shuts down the amplifier in case of overheating.
Battery Fusing Rates (External to Amplifier) 20 amps 30 amps 40 amps 50 amps
Fuse Type ATC ATC ATC AGU
Equalization Bass: +18dB Maximum at 45Hz
Treble: +12dB Maximum at 20kHz
Input Impedance 20k ohms
Editado por Motta Slp
Visitante
