AndCamp®
Rockford Fosgate Punch P4004
Rockford Fosgate Punch P4004 (R$580,00)
Extremamente novo
Parcelo no Mergado Pago (taxas e juros por conta do comprador)
Especificações
Canais: 4
Total Power:
400 Watts RMS
Rated Power:
50 Watts x 4@4-Ohm
100 Watts x 4@2-Ohm
200 Watts x 2@4-Ohm Bridged
Bridgeable: Sim
Frequence Response: 20Hz to 20kHz +/- 0.5 dB
Circuit Topology Class: Class A/B
Signal Input: Low level: 2 RCA pair - Input switch: 2/4 ch.
Signal Output: Low level: 1 RCA pair
Tone Controls: Bass: 0dB to +18dB @ 45Hz
Crossover Controls: High-Pass (HP): 40-400Hz 12dB/octave Butterworth; Low-Pass (LP): 40-400Hz 12dB/octave Butterworth
Visual Indicators: Power On, Signal Level, Thermal Status e Speaker Protection
Power Wire Gauge: 4 AWG
Power Imput Connector: Block
Speaker Wire Gauge: 8 AWG to 18 AWG
Speaker Output Connector: Screw terminal barrier strip
Cooling: Convection
Shipping Weight: 17.5 Lbs. (7.9 Kg.)
Equally adept at powering two pair of coaxials/component speakers or one pair of speakers and a 4-ohm SVC subwoofer, the P4004 is a solid amplifier choice for virtually any vehicle.
  • Stealth Connections
  • 4 Gauge power/ground connections with built-in ATC fusing
  • Connector Cover
  • Focused mass heatsink design
  • RF Logo with Interactive Signal Display
  • Thermal Sensing
  • Infrasonic filter
  • Aux Ouputs
  • 1 Year Warranty
ola ainda tem? esse é uma linha abaixo do punch e power daqueles cinzas mais quadrados com abas? o 400a2 e 400a4 ?
