JeanCan
[VENDO] Amps Rockford Fosgate Prime R1000-1D e Alpine MRP-F300
Ambos os amp nunca foram abertos, nunca apresentaram problema. Estão em perfeito estado.
Motivo da venda: Troquei de carro e hora de diminuir a quantidade de som.
Rockford Fosgate Prime R1000-1D - R$ 850 reais
Especificaçôes:
mono subwoofer amplifier
500 watts RMS x 1 at 4 ohms (1,000 watts RMS x 1 at 2 ohms)
CEA-2006 compliant
variable low-pass filter filter (40-130 Hz, 12 dB/octave)
variable bass boost (0-12 dB at 45 Hz)
wired remote Punch Level Control included
Class-D amplifier design
frequency response: 20-130 Hz
MOSFET power and output stages
preamp-level inputs and outputs
4-gauge power and ground leads recommended — wiring and hardware not included with amplifier
fuse rating: 30A x 3
12-1/8"W x 2-7/16"H x 7-11/16"D
Alpine MRP-F300 R$ 450 reais
Especificaçôes:
4-channel car amplifier
50 watts RMS x 4 at 4 ohms (75 watts RMS x 4 at 2 ohms)
150 watts RMS x 2 bridged output at 4 ohms (4-ohm stable in bridged mode)
2-, 3-, or 4-channel output
variable high-pass/low-pass filters (50-400 Hz, 12 dB/octave)
selectable bass boost (12 dB at 50 Hz)
subsonic filter (15 Hz, 18 dB/octave for channels 3 & 4)
MOSFET power supply
CEA-2006 compliant
STAR Topology (minimizes internal noise and prevents ground interference)
speaker- and preamp-level inputs
gold-plated screw terminals
fuse rating: 25A x 2
8-gauge power and ground leads recommended — wiring and hardware not included with amplifier
10-11/16"W x 2-7/16"H x 9-9/16"D
Qualquer dúvida, estou a disposição. Produtos se encontram em Itajaí - SC.
Editado por JeanCan
