dfcarrilho
POSTADO EM LOCAL ERRADO POR FAVOR FECHAR
Vendo amplificador helix db four 4 canais...usado porém em perfeito estado de conservação...tenho apenas o manual, não possuo mais a caixa.
Especs
4-channel car amplifier
60 watts RMS x 4 at 4 ohms (90 watts x 4 at 2 ohms)
180 watts RMS x 2 bridged output at 4 ohms (4-ohm stable in bridged mode)
Class A/B design
variable low-pass filter (15-4000 Hz)
variable high-pass filter (40-4000 Hz)
bass boost (0-18 dB at 45 Hz )
speaker-level inputs via 8-pin harness
preamp inputs and outputs
8-gauge power and ground leads recommended — wiring and hardware not included with amplifier
fuse rating: 25A x 2
Valor R$ 400,00
Anúncio mercado livre com fotos
http://produto.mercadolivre.com.br/MLB-861481275-amplificador-helix-db-four-4-canais-_JM
Editado por dfcarrilho
