raphael moreira
[Vendo] Amplificadores Super Pro Piramyd 1000 e Clarion 4241 APX
Boa tarde galera, estou desapegando dos meus amplificadores, ambos estão 100% originais nunca foram abertos ou mexidos
Super Pro 1000 Especificações
PYRAMID SUPER PRO ( PRO 1000)
PYRAMID PRO 1000 (1000-Watt)
Four Channel Amplification
Bridgeable to 4/3/2 Channel Configuration
Center Channel Capable
Variable Gain Control
Remote Turn On/Off Circuit
Dual-MOSFET Pulse Width Modulated Power Supplies
Front and Rear Fully AdjusabIe High/Low Pass Crossovers
Gold Plated Speaker Output Barrier Strip
High Level Low Impedance MOLEX Inputs
Delayed Soft Turn-On Circuit
Power On LED Indicator
Power Output:
4 x 125 Watts RMS @ 4 Ohms
2 x 250 Watts RMS @ 4 Ohms (BRIDGED)
4 x 200 Watts RMS @ 2 Ohms
4 x 250 Watts Peak Power 1000 Watts Total
Peak Output 1000 Watts Peak Momentary Power Output
Speaker Impedance: Stereo Mode: 2-8 Ohms / Bridged Mono Mode: 4-8 Ohms
Dual Crossover (Front and Rear Channels): High Pass Filter Adjustable from 30-500Hz Low Pass Filter Adjustable from 50-250Hz
Bass Boost: 6dB @ 100Hz
Signal to Noise ratio >95dB
THD @ RMS 1kHz 0.04%
Channel Separation: 80dB
Frequency Response: 10-35k Hz
Bass Boost Circuit
Gold Plated High Impedance RCA Inputs
Inputs: RCA Low Level: 0.1-1V High Level Low Impedance:1-10V
Protection Circuits: Thermal, Short Circuit,Current, Reverse
Heavy Duty Aluminum Alloy Heatsink with Die Cast End
Amplificador Clarion 4241 APX
Na segunda foto estava faltando 1 parafuso, mas já foi colocado***
Fotos
AMPLIFICADORES CLASSE AB
  • 400 Watts de máxima potência musical
  • 80W x 4 com 2 Ohms, @<0,1%>
  • 60W x 4 com 4 Ohms, @ < 0,1%="" />
  • Aumento de Baixa Selecionável; 0/6/12dB @ 50Hz
  • Crossovers Passa Baixa/Alta -12db/Oct. Ajustáveis, Independentes, Dianteiros e Traseiros, 50-300Hz
  • Conectores revestidos de ouro; RCA/ Alto-falante/ Eletricidade
  • Entrada de nível de alto-falante
  • Dimensões 11-7/8" x 11" x 2-1/4"
Potência CEA 2006
80W x 4 RMS [4Ω @14.4V ≤1% THD+N]
S/N 75dB (Ref: 1W em 4Ω)
Preços Pyramid 150 reais com manual e se achar as abas também irão junto
Clarion APX 4241 200 reais com manual completo
Os 2 juntos sai a 300 reais...
Contato 13-99651-5054
Editado por raphael moreira
Visitante
