Wagnercruz
Clarion XH5410 640W Max XH Series 4-Channel Amplifier
Vendo Modulo Clarion,
500 com frete gratis via mercado livre.
http://www.clarion.com/us/en/products/2012/audio/amplifiers/XH5410/us-en-product-pf_1259559424424.html
4/3/2 Channel Power Amplifier
FEATURES
  • Maximum Power Output : 680W
  • Power @ 4-Ohm : 90w x 4
  • Power @ 2-Ohm : 160W x 4
  • Bridged @ 4-Ohm : 320W x 2
  • Input Voltage Selector (I.V.S.) Sensitivity Control
  • Precise Frequency Selector (P.F.S.) Crossover Control
  • Precise Frequency Selector -18dB /Oct. High/Low Pass Crossover, 50Hz - 575Hz, 525Hz - 5.8kHz
  • Number of Channels : 4/3/2
  • MOS-FET Power Supply
  • 2-Ohm Stereo Stable
  • Independent Front / Rear Adjustable - 12db/Oct. High/Low Pass Crossovers, 55Hz-600Hz or 530Hz-5.8kHz with the Crossover Frequency Multiplier
  • Variable Bass Boost; 0-15dB @ 45Hz
  • Gold Plated Connectors; RCA/ Speaker/ Power
  • Speaker Level Input
  • Dimensions(W x H x D)(Inchs) : 14-11/16" x 2-5/8" x 9"
Circuit Design Achieves High Quality Sound (XH Series)
Clarion amplifiers feature uncompromising resistance to magnetic noise, thereby minimizing distortion, as well as gold-plated block terminals to offer low electrical and contact resistance. Easy subwoofer system configuration is possible with the embedded high-pass and low-pass filters. The result is high quality sound you can enjoy in a variety of systems.
Gold Plated RCA and Block Terminal on all XH series Amplifiers
By utilizing gold-plated RCA and block terminals, XH series amplifiers offer increased conductivity and low signal loss. Gold has an extremely low electrical resistance and low contact resistance, which helps to prevent voltage drops, noise, over heating and other problems from occurring.
MOS-FET Power Amp
There’s only one way for Clarion’s source units to deliver unyielding power output and linearity: MOS-FET amplification, or Metal Oxide Semiconductor Field Effect Transistor amplification. Smaller and more efficient than conventional power supplies, a MOS-FET amplification circuit delivers power with less distortion and zero On/Off switching noise. This means you can crank up the volume or set it to easy listening. Either way, your sound will be crystal clear.
2-Ohm Stability
Utilizing this design for peak performance and unwavering reliability, Clarion's amplifiers can drive lower impedance loads for increased power.
CEA 2006 Power Ratings
100W x 4 RMS [4Ω @14.4V ≤1% THD+N]
S/N 86dB (Ref: 1W into 4Ω)
Visitante
