srg.canellas
[vendo] Player Rockford Fosgate Denford-8250 PROMOÇÃO
Vendo player feito pela rockford fosgate com parceria com a denon.
Valor: 1.350,00
http://produto.mercadolivre.com.br/MLB-888320161-player-rockford-fosgate-rfx-8250-_JM
SPECIFICATIONS Specifications subject to change without notice General 8240 8250 Operating Voltage +10.8V – +16.0V DC +10.8V – +16.0V DC Standby Current 5mA Max 5mA Max Operating Temperature Receiver: -30°C to +70°C Receiver: -30°C to +70°C CD Player: -10°C to +65°C CD Player: -10°C to +65°C Preamp Output Voltage >2.0V RMS @ 0.5% THD 5V RMS @ 0.5% THD Preamp Output Impedance <100¿ <50¿ Equalization Bass: ±12dB @ 100Hz Bass: ±12dB @ 100Hz Treble: ±12dB @ 10kHz Treble: ±12dB @ 10kHz Overall Dimensions Height: 1-31/32" (50mm) Height: 1-31/32" (50mm) Width: 7" (178mm) Width: 7" (178mm) Depth: 6-13/32" (163mm) Depth: 6-13/32" (163mm) Weight (Mass) 3.75lbs (1.7kg) 3.75lbs (1.7kg) FM Tuner Tuning Range 87.9 ~ 107.9MHz (200kHz spacing) Usable Sensitivity 14.8dBf Signal-to-Noise Ratio 70dB (IHF-A) Distortion < 0.5% Channel Separation 40dB @ 1kHz Suppression 20.3dBf AM Tuner Tuning Range 530 ~ 1710kHz (10kHz spacing) Sensitivity 30µV CD Player Compatible Discs 5" Frequency Response 20Hz – 20kHz (±3dB) Signal-to-Noise Ratio >90dB (preamp output w/ 22kHz LP filter) Distortion <0.5% Channel Separation 86dB (preamp output w/ 22kHz LP filter) Dynamic Range 100dBczljlEe.png
Editado por srg.canellas
Visitante
