pedromsf
Amplificador MB Quart OA1100.5 canais
Vendo amplificador pouco usado em perfeito estado
Segue manual, acessórios, ferramentas, caixa, plasticos.
Onyx Series 5-Channel Class D Car Amplifier
Channel 1-4 Max Power Rating:
4 ohms: 75 watts x 4 chan.
2 ohms: 150 watts x 4 chan.
Subwoofer Channel Max Power Rating:
4 ohms: 350 watts x 1 chan.
2 ohms: 500 watts x 1 chan.
Max power output: 1100 watts total
FLUID-FETS MOSFET Circuit maximizing power efficiency while improving sound quality
LED power (green) and protect (red) indicators
Variable BassEQ Boost (0 to +12 dB bass boost fixed at 45 Hz)
Built-in system diagnostics
Mono channel operation
Preamp RCA outputs to daisy chain multiple amps
3-way protection circuitry (thermal, overload, and speaker short protection)
Heavy duty Black Onyx aluminum alloy heat-sink with illuminated MB Quart design
Input sensitivity:
Level: 200mV-6V
2 gauge power and ground wiring is required for installation. Contact us for information regarding a discount on select amplifier kits from our website when purchased together with this amplifier.
Dimensions: 9-7/16"W x 16"D x 2-1/4"H
http://produto.mercadolivre.com.br/MLB-814058144-amplificador-mb-quart-oa-11005-canais-_JM
VALOR: R$ 1.000,00
