ivancd
[VENDO] Subwoofer Ground Zero GZIW 200X 8pol - Lacrado nunca usado
SUBWOOFER GROUND ZERO
NOVO - LACRADO NA CAIXA
Model  GZIW 200X
Diameter 20 cm / 8"
Cone IMPP
Power Handling 150 WRMS
Impedance
4 Ohm
SPL 87 dB
Xmax 12 mm / 0.47"
Fs 38.4 Hz
Qts 0.48
Vas 27 L / 0.95 cu.ft.
Sound Quality*
SPL Competition*
Low bass performance 20 - 50 Hz*
Mid bass performance 50 - 80 Hz*
CAIXA DUTADA
15 Liter / 0.53 cu.ft Rohr / Tube 1x Ø 7cm / 2.76" L= 21 cm / 8.27"
CAIXA SELADA
9 - 15 Liter / 0.32 - 0.53 cu.ft
VALOR: R$ 355,00
(aceito mercadopago, depósito e trocas)
Seguem fotos reais
Visitante
