Leo Real
Alpine TDM-7531
Falae galera.
Alguem tem a ficha tecnica desse Toca-Fitas ae???
Valeu
aCHO que vai ser muito dificil, mas eu tenho um deste.
o que vc precisa saber dele???
Ele não tem RCA, mas aceita disqueteira e fica muito bom, otimo aparelho para um carro simples de dia a dia.
otimas respostas para ligar direto em falantes e seu radio é muito bom e de otima sintonia.
tambem controla disqueteira facil por ele, mas é sistema I-Bus não não I-net
Falae galera.
Valeu
4x30
1 par de rca
e saida pra disqueteira m-bus
Falae galera.
Valeu
4x30
1 par de rca
Detachable Face FM/AM Cassette
Reciever/CD Shuttle Control
Features
GENERAL
• SOURCE TONE MEMORY (S.T.M.) - Automatically
memorizes the settings of bass and treble controls for
each source.
• DIGITAL CLOCK
• ISO MOUNTABLE
• LOUDNESS COMPENSATION SWITCH
• CUSTOM HIGH GRADE AUDIO CAPACITORS
• REAR 24Kt GOLD PRE-AMP OUTPUTS
• SELECTABLE PRE-AMP FADER
• REMOTE CONTROL OPTIONAL
• 25 x 4 MAXIMUM POWER OUTPUT
TAPE PLAYER
• SCC TAPE HEAD
• GR FULL LOGIC MECHANISM
• AUTO METAL
• POWER-OFF PAUSE - Releases the pinch roller to
avoid damage without ejecting the cassette.
TUNER
• MaxTune™ ENHANCED TUNER - Surpasses the
performance of The T-10 IISP, with increased sensitivity
and improved multipath noise rejection.
• INTELLIGENT AUTO MEMORY (A. MEMO) - In the
Auto Memory mode, the 6 strongest stations in each
band will be stored automatically in the memory
presets.
• DIRECT ACCESS PRESETS (D.A.P.) - Allows the
storing of both AM and FM stations on the same band.
Up to 6 stations can be stored in the D.A.P. band.
• AUTOMATIC FM STEREO/MONO SWITCHING -
Changes to mono mode with weak signals to reduce
the noise level. Returns to stereo mode when the
signal is strong enough for noise-free reception.
CD SHUTTLE CONTROL
• MUSIC SEARCH UP, DOWN
• M.I.X. - Plays the selections on a disc in a random order
• DIRECT DISC SELECT
• DISC SCAN, REPEAT, PAUSE
Specifications
FM TUNER
Tuning Range .................................................... 87.7-107.9 MHz
Mono usable sensitivity ................... 9.3dBf(0.8mV/75 ohms)
50dB Quieting sensitivity .............. 13.5dBf(1.3mV/75 ohms)
Alternate Channel Selectivity ........................................... 80dB
Signal -to-Noise Ratio ......................................................... 65dB
Stereo Separation ................................................................. 35dB
Capture Ratio ....................................................................... 2.0dB
AM TUNER
Tuning Range ....................................................... 530-1,710 kHz
Usable Sensitivity ............................................. 22.5mV/27.0dB
TAPE PLAYER
Tape Speed ...................... 1-7/8 in./sec. (4.8 cm/sec.)± 0.7%
Wow and Flutter ................................................................ 0.07%
Signal-to-Noise Ratio ......................................................... 60 dB
Frequency Response (Alpine test tape)30-20kHz .... (± 3dB)
POWER OUTPUT
Maximum Power Output (Note) ....................................... 25x4
Continuous Power Output (Note) ...................................... 9x4
GENERAL
Pre-out Voltage (Vol. centered, into 10 kW) .............. 500mV
Pre-out Voltage (Maximum) ................................................. 2V
Bass Control Range ........................................... ±15 dB at 30Hz
Treble Control Range ......................................±10dB at 10kHz
Power Requirement .............. 11-16V DC (Negative ground)
Mounting Angle ............................... Within 30° of horizontal
Chassis (WxHxD) ........................................................... 7"x2"x6"
Nosepiece size (WxHxD) .................... 6-3/4x1-13/16x11/16
Weight................................................................. 2lb.12 oz(2.2)kg
Note 1: Under maximum operatating voltage and input signal, into 4 ohm loads.
Note 2: Per EIA -517 Std, 40Hz to 20kHz, 0.8% THD, at14.4V DC supply
Brigadão ae galera.
É q eu to com 1 amigo meu q tem esse T/F no carro com disqueteira, mas naum tem manual nem nada.
Ele tá querendo instalar um modulo com uma caixinha mas naum sabia dizer se tinha RCA.
Valeu pela ajuda.
Falae galera.
Valeu
Gostaria de ligar um mp3 pela entrada da disqueteira nesse tf alguem sabe a configuracao do cabo?
é original do tempra...
dá pra fazer esquema de ele aceitar um cabo AUX sim, mas precisa deturpá-lo (oia que palavra chique!) a acreditar que tem uma disqueteira conectada na saída M-Bus dele
é um aparelho legal legal; se fosse pra ter so um toca-fitas, não teria outro...
boa sorte
