Carro do Leite
Amplificador JL XD 600/1 Vendido!
Vendido!
Por favor só entra em contato para fechar negocio.
  • Não aceito trocas
  • Preferencia para retirar em mãos
  • Só me chama se tiver realmente interesse.
  • Somente dinheiro
  • Aceito Mercado Pago
  • Aceito Retirada em mãos
  • 11 941938016 Whats
Amplificador JL XD600/1
  • mono subwoofer amplifer
  • 400 watts RMS x 1 at 4 ohms (600 watts RMS x 1 at 2 ohms)
  • variable low-pass filter (50-500 Hz, 12 or 24dB/octave)
  • subsonic filter (30 Hz, 24 dB/oct)
  • optional wired remote for level control
  • Class D amplifier design with NextD™ switching amp technology
  • differential-balanced inputs eliminate noise coming from your vehicle's electrical system
  • Advanced Rollback Protection System prevents thermal shut-down
  • speaker- and preamp-level inputs (speaker-level input requires an optional adapter)
  • preamp outputs
  • 4-gauge power and ground leads and a 50-amp fuse recommended — wiring and hardware not included with amplifier
  • no onboard fuses — when installing multiple amps in a system, an additional 50-amp in-line fuse between the distribution block and the amplifier is recommended
  • 8-1/2"W x 2"H x 7-3/8"D
Editado por Carro do Leite
Visitante
