pirrata
[Vendo]Audiophonic CLUB 800.4/V2 + 2 Rca Clube Zerado!
Vendo audiophonic
Audiophonic CLUB 800.4/V2 + 2 par rca clube   Novos no plástico
R$ 1189,00
Especificações:
  • Power @ 4ohm - 4 x 120W RMS
  • Power @ 2ohm - 4 x 190W RMS
  • Power @ 1ohm - N/A
  • Bridge @ 4ohm - 2 x 360W RMS
  • Total Harmonic Distortion - 0,07%
  • S/N Ratio Ref 1WAT @ 4ohm - >85dB
  • Efficiency - 88%
  • Gain Range - 0.2V/6V
  • Crossover Range - 50Hz-250Hz
  • Frequency Range - 15Hz-35.000Hz
  • Subsonic - N/A
  • BassBoost - 0dB-18dB
  • Bass EQ - N/A
  • Fuse - 2x30A
  • Phase - 0-180º
  • Input Sensivity (Low Input Level) - 200m V-5.0V
  • Input Sensivity (High Input Level) - N/A
  • THD 4 (1 KHz @ 4ohm) - 0,50%
  • Idle Curret - 0.7A
  • Power and Ground cable - 8 AWG
  • Weight - 1,24kg
  • Audio Input - High/Low
  • External Fuse - 100Ah
  • Master/Slave - N/A
  • Max ampere comsuption - 65Ah
  • Measure - 210,6 x 125 x 42 (mm)
Editado por pirrata
