Suspensa! Amplificador DLS A5
- Number of channels: 3
- Amplifier class: AB
- Output power in: 2 ohm 2 x 100 W RMS
- Output power in: 4 ohm 2 x 85 W RMS
- Mono sub channel output in: 1 ohm 780 W RMS
- Mono sub channel output in: 2 ohm 500 W RMS
- Mono sub channel output in: 4 ohm 300 W RMS
- Damping factor >200 S/N ratio, A-weighted >100 dB
- Frequency range: 10 Hz - 50 kHz
- Input sensitivity: 0,2 - 7V
- Input impedance: >10 kohm
- Filters channel A & B HP: 50-150 Hz
- Low level output: No
- Remote bass level control: Yes
- Remote phase shift control: Yes
- High level input with auto start: No
- Integrated fan: No
- External cooling fan terminal: Yes
- Power consumption (idle): 0,5 A
- Power consumption (max): 90 A
- Rec. power cable Minimum: 4AWG / 21 mm2
- Fuses: 3 x 30 A
- Dimension (W x D x H) 410 x 240 x 73 mm (16,15 x 9,45 x 2,87 inch)
- Weight 5,9 kg (13 lb)
OBS: Possui caixa e acessórios.
Valor: Suspensa!
Editado por gustavomp3
Visitante
