acz
[vendido] Processador Alpine 5.1 PXA H510 com RUX
VALOR: R$670 com frete grátis pelo MercadoLivre
http://produto.mercadolivre.com.br/MLB-759496803-processador-alpine-pxa-h510-com-rux-dsp-_JM
Processador Alpine 5.1 PXA H510 com RUX.
Com a RUX, permite que funcione com aparelhos não Alpine, através de conexão RCA Analógica ou Optico.
Com aparelhos Alpine, pode ser ligado via Ai-NET.
Dolby Dolby Pro Logic and Dolby Digital
Speaker System:
Front / Large, Small
Centre / Large, small, Off
Rear / Large, small, Off
Channel Level -10 - +10 (1 dB/step)
Independent of Front-L / Front-R / Rear-L / Rear-R / Centre BI-PHANTOM
Level +/- 5dB (1 dB/step)
Rear MIX Level +/- 6dB (3 dB/step)
Centre Delay 0 - 5ms (1 ms steps)
Rear Delay 0 - 5ms (5 ms steps)
Listening Mode Standard / Maximum / Late Night
Parametric EQ:
Front and Rear: Band 1: 20Hz - 630Hz (1/3 oct),
Band 2: 63Hz - 2kHz (1/3 oct),
Band 3: 200Hz - 6.3kHz (1/3 oct),
Band 4: 630Hz - 20kHz (1/3 oct)
Centre: Band 1: 100Hz - 2.5kHz (1/3 oct),
Band 2: 315Hz - 8kHz (1/3 oct)
Subwoofer:
Band 1: 20Hz - 80Hz (1/3 oct)
Level 9dB (1.8dB step)
Q Factor 1.0/2.0/5.0
Time Correction:
Adjustable Time: 0.0 ms - 20.0 ms (0.1ms/step)
Independent Front-L / Front-R / Rear-L / Rear-R / Centre Subwoofer
Control:
Subwoofer Level Control: 0 - 15dB (1dB step)
Cut Off Frequency: 80Hz
Surround Function:
Preset Memory: Normal / Stadium / Live / Church / Hall / Dance
Adjustable Level Control: -4 - +4 (9 step)
Adjustable Time Control: -4 - +4 (9 step)
Input Mode:
3 Optical Digital Inputs
Analog RCA Input
Ai-NET Input
Output Mode:
Front / Rear / Centre / Subwoofer
Dimensions:
Base Unit 240 x 50 x 160 (mm)
Control Unit 113 x 19 x 39.5 (mm)
General:
6 Private Memory Setting
Signal-to-Noise Ratio: 105dBA
Channel Separation: 70dB
Input Sensitivity: 850mV
Editado por acz
Faz 3 way com cortes independentes por canal ou cortes já pre definidos? TÁ dele é legal?
Esse não faz 3 way.
Posso ligar bom player original do carro? No caso sem rca
Infelizmente não tem entrada alta. Só usando algum conversor RCA.
Tem interesse em um IDA-X100 com uma PXA-H100 na troca? Um pelo outro...
Desculpe Marcos Vinicius, parece que o forum não está me notificando, só vi agora.
Agradeço a oferta, no momento não teria uso, e trocar para deixar guardado não teria sentido, por já estar colocando à venda um item que está parado.
Up!
Aceito SD 400.4 Evo como parte do pagamento.
Up!
Também analiso propostas em dinheiro, vai que..  [¨]
Visitante
