fernando_cesar
(VENDO) MTX THUNDER 8 1000D (1.500 w rms - 2ohm) (R$ 800,00)
MTX THUNDER 81000D
LOCAL: SÃO PAULO (ZONA SUL)
VALOR: R$ 800,00
CONTATO EMAIL: FERNANDO_CESAR@YMAIL.COM
TENHO ARQUIVO DO MANUAL SE ALGUÉM PRECISAR.
THUNDER 81000D
RMS Power measured at 12.5 Volts DC:
500 Watts x 1 into a 4 Ohm load with less than 2% Thd+N
1000 Watts x 1 into a 2 Ohm load with less than 2% Thd+N
Dynamic Power measured at 14.4 Volts DC
850 Watts x 1 into a 4 Ohm load
1500 Watts x 1 into a 2 Ohm load
Signal to Noise Ratio: ≥100dB A-Weighted
Damping Factor: >100
Frequency Response: 20Hz-200Hz
Maximum Input: 8Vrms
Thunder EQ: Variable Bass Boost (0-18dB) centered at 40Hz
Crossover: Variable 40Hz to 200Hz, 24dB/octave low pass
Dimensions:15.4" x 9.75" x 2".(40.1cm x 24.8cm x 5.1cm)
17.8" x 9.75" x 2.1" (45.2cm x 24.8cm x 5.3cm) Including IsoFeet™
Recommended Fuse = 150A
Editado por fernando_cesar
