marcelosantos
QUAL D0S 3 MODULOS É UMA MELHOR COMPRA ?
Pessoal vou comprar um modulo para tocar meu set,estou usando um player clarion DXZ 786-usb e kit hertz ESK165 L subwoofer Nar 12sw3D6 fazendo uma pesquisa na internet me deparei com 3 modulos e fiquei na duvida entre os 3,por isso gostaria de ouvir a opnião de voces qual dos 3 modulos me atenderia mais com qualidade e potencia para meu setup.
MB QUARTZ ONX4125 VALOR 691,00 VOU TRAZER DE FORA !
Power Specifications - Full Range Channels
RMS Power @ 4 ohms 125 watts x 4 channels
RMS Power @ 2 ohms 250 watts x 4 channels
RMS Power @ 1 ohm N/A
Bridged RMS Power 500 watts x 2 channels
Peak Power Output 1000 watts x 2 channels
Amplifier Specifications
Amplifier Class AB
Number of Channels 4
Total Peak Power Output 2000 watts
Total RMS Power Output 1000 watts
Maximum Input Gauge Size 4 AWG
Minimum Impedance Unbridged 2 ohms
Minimum Impedance Bridged 4 ohms
THD at Rated RMS Power 0.05%
Speaker Level Inputs No
Preamp Outputs 1 pair
Built-in Crossover Low-pass (LP)
High-pass (HP)
Full (AP)
High-Pass Crossover Frequency 60 - 13,000 Hz
Low-Pass Crossover Frequency 30 - 250 Hz
Subsonic Filter N/A
Signal-to-Noise Ratio >92 dB
Channel Separation >80 dB
Bass Boost 0 - 12 dB
Bass/Gain Remote No
Fan Cooled No
Fuse Rating 40A x 3
CEA-2006 Compliant Yes
JBL GTO 1004 VALOR 732,00
Especificações:
Description
600-Watt 4-Channel Full-Range Amplifier
Series
Grand Touring
THD + N
0.05% (rated power @ 4 ohms)
Output power (RMS, ≤1% THD + N; 2 ohms)
150W RMS x 4 channels
Output power (RMS, ≤1% THD + N; 4 ohms)
100W RMS x 4 channels
Crossover
Built-in variable electronic crossover
Signal-to-noise (@ 1W)
85dBA
Frequency Response
10Hz – 100kHz (–3dB)
Maximum power
600W
Inputs
RCA low-level preamp inputs
Outputs
RCA low-level preamp outputs
Back-lit
JBL logo badge & dual LED light bars
Bass boost (+6dB @ 50Hz)
Variable bass boost (0 to +12dB @ 50Hz)
Dimensions (L x W x H)
472mm x 264mm x 54mm (18-9/16" x 10-3/8" x 2-1/8")
AUDIOPHONIC CLUB 800.4 VALOR 585,00 esse ai eu coloquei em 3º lugar por causa de algumas pessoas aqui do forum dizer que o modulo esquenta muito e entra em proteção constantemente.
Número de canais: 4 Canais
Potência RMS @4 Ohm 4x100 Watts
Potência RMS @2 Ohm 4x200 Watts
Bridge Mode Power @ 4 Ohm 2x395 Watts (Mono)
Resposta de frequência 10Hz ~ 60kHz
Relação sinal/ruído > 90 dB (+A)
THD @ 4Ohms <0.03 %
Sens. Entrada (Low Level) 200mV ~ 5V
Estereo Separation >(+A) 87dB
Alimentação + 12V (10,5 ~15V)
Fusíveis 40A x2
Dimensões 257x54x387mm
agradeço aos usuarios Cirors / miguel nicolau / andre junqueira pela ajuda na escolha do modulo.
Andre ja procurei esse modulo aqui em são paulo e ele sai mais caro do que importar,ja encontrei pelo valor de R$ 1592 e importando eu trago ele por R$691,00 minha outra duvida é que em alguns sites esse modulo aparece como classe D e em outros como classe AB eu quero um classe AB para tocar meu stereo,vou verificar melhor para não comprar errado.
se voces tambem quiser opniar por outro modelo e frabricante eu tambem agradeço posso gastar ate uns 600 a 900 reais nesta compra !
Nao to por dentro da disponibilidade deles atualmente, mas achava Clarion APX4361 e Hertz EP4x, por aqui na faixa dos 900 reais.
Comprei meu APX4361 na r2audio ano passado.
Eu iria de MB tb, falam mt bem dele.
Sem querer me entrometer muito no tópico, até mesmo pq não quero criar um tópico novo, queria saber se um sd250 preta pra um SQ de entrada, e é meio temporário até montar um bom SQ mesmo...
seria pra tocar um Helix B10E: http://www.audioschulz.com.br/helix/blue/subwoofer/caixa-b10e.html
alguém quebra esse galho pra mim?
AbraÇos!
