Rodrigo Lima E2K
Amp Alpine MRP-450 400wrms x Sub RE Audio REX12D4 175wrms
Pessoal, meu som já ta em fase final de compra de equipos... pra parte de grave, já tenho o amp alpine mrp-450. Seguem as specs:
mono subwoofer car amplifier
220 watts RMS x 1 at 4 ohms (400 watts RMS x 1 at 2 ohms)
variable low-pass filter (50-200 Hz, 24 dB/octave)
tuned Bass EQ (0-12 dB bass boost at 50 Hz)
subsonic filter (15 Hz, 24 dB/octave)
MOSFET power supply
CEA-2006 compliant
STAR Topology (minimizes internal noise and prevents ground interference)
speaker- and preamp-level inputs
gold-plated screw terminals
fuse rating: 20A x 2
8-gauge power and ground leads recommended — wiring and hardware not included with amplifier
9-3/4"W x 2-7/16"H x 9-9/16"D
warranty: 1 year
Pra ser tocado por este amp, pensei no subwoofer RE audio:
Subwoofer 12" RE Audio
REX12D4 - REX series
175W RMS @ 4+4Ohm
Entry level line that is anything but "entry level". The RE SERIES offers incredible output and sound quality from small sealed or ported enclosures.
• Mica Filled Poly Cone
• Santoprene Rubber Surround
• Pressed Steel Basket
• High Temp 8-layer Copper Voice Coil
• FEA Optimized Motor Structure
• Single Magnet
• Linear Conex Spiders
• Foam Gasket
Descrição do Produto
REX SERIES
T/S Parameters
Electrical Q Value -Qes: 0.42
Mechanical Q Value -Qms: 4.27
Total Speaker Q Value -Qts: 0.38
Free Air Resonance -Fs: 20.0 Hz
Equivalent Compliance -Vas: 182 liters
One-Way, Linear Excursion -Xmax: 12 mm
Efficiency -SPL 1W/1m: 87.3 dB SPL
Effective Piston Area -Sd: 500 cm^2
DC Resistance -Re: 3.2 ohm
Nominal Impedance -Znom: Dual 4 ohm
Thermal Power Handling -Pe: 175 W
Force Factor -Bl: 15.4
O que me dizem ? é um bom casamento ? Qual seria a caixa ideal para este sub? pensei em selada...
Ele aguenta 400wrms na bunda dele ?
Rodrigo td bom?
Não conheço sub da RE, mas o Clayton teve um e falou mt bem dele. Ele é bem fortinho, acho que rola sim 400rms nele, só vc regular o ganho. Quanto a caixa depende do tipo de música ou sé quer mais spl ou qualidade.
Rodrigo td bom?
Vlw daran! sabe dizer quantos RmS o Clayton aplicava nele ?
Um lojista me indicou um sub da hertz modelo ES300.. a fs dele é um tanto mais alta... e pela sensibilidade fico meio achando que é um sub mais voltado pra spl..
segue as specs do hertz ES300
