gmrc
Fosgate ou Diamond
Ola galera, estou para usar 1 desses 2 modulos, gostaria da opinião de vcs sobre qual amp é melhor em termos de qualidade e potencia real. Caso seja o fosgate melhor, tenho 1 cros digital para meus falantes. []-[]
Rockford Fosgate Punch 200x2 Trans-Ana
Specifications:
Measured at 14.4 battery volts
• 150 Watts RMS per channel into 4 ohms
• 240 Watts RMS per channel into 2 ohms
• 500 Watts RMS mono into 4 ohms
• Less than .05% total Harmonic Distortion into 4 ohms and less than .10% into 2 ohms from 20-20,000 Hz
THD <0.5%
Signal Noise Ratio: >93dB
Damping Factor: >200
Diamond Audio D6 450.2
Measured at 12.6/14.4 battery volts
RMS Power (4 ohms) 125 watts x 2 channels
RMS Power (2 ohms) 225 watts x 2 channels
High-Pass Crossover Frequency 30 - 500 Hz
Low-Pass Crossover Frequency 30 - 500 Hz
Internal 12dB/Octave High Pass or 24dB/Octave Low Pass Filter (30-500Hz)
THD <0.2%
Signal Noise Ratio: >95dB
Damping Facotr: >200
