Felipe C.
Tweeter queimado, ajuda em escolha de outro ( Alpine )
Ae galera beleza?
Tenho um kit duas vias Alpine SPX-17REF, indicado por um amigo forista.
O que acontece é que meus tweeters queimaram, estou com tweeters provisórios bravox, porem
gostaria de colocar algo ao nível do kit.
    *  6-1/2" Type X Series Component System
   * FREE Speaker Adapters Included: 6-3/4" and 5" x 7" adapters included.
   * Power Handling:
         o Peak: 450 watts per set / 225 watts each side
         o RMS: 150 watts per set / 75 watts each side
   * Cross-rib aluminum cone
   * (NBR) Nitrile Butadiene Rubber surround
   * 1" Dome tweeter
   * Cast aluminum frame
   * Multiple crossover tuning options with minimum phase shift
   * 4 ohms impedance
   * Thermal transfer crossover chassis design
   * Heat sink resistors
   * Heavy gauge air core inductors
   * Metalized poly capacitors
   * 4-Level tweeter adjustment
   * Tweeter protection
   * Gold plated insert with tab
   * Secure one-snap cover
   Tweeter Design	Dome
Tweeter Composition	Not Specified
Woofer Composition	Aluminum
Woofer Surround	Nitrile Butadiene Rubber (NBR)
Peak Power Handling	225 watts
RMS Power Handling	75 watts
Sensitivity	90 dB
Frequency Response	35 - 40000 Hz
Impedance (per voice coil)	4 ohms
O kit esta ligado no amp MTX TE604
# Thunder Elite 4-Channel Class AB Car Amplifier
# RMS Power Rating:
   * 4 ohms: 80 watts x 4 chan.
   * 2 ohms: 150 watts x 4 chan.
   * Bridged, 2 ohms: 600 x 1 chan.
# Max power output: 1200 watts x 1 chan.
# Semi Unregulated MOSFET
# Remote bass level input (remote level control sold separately)
# Dual Mono Output
# Overload and Thermal Protection
# High Level with Smart Engage Auto Turn-on RCA Input
# Input Select 2/4 Channel
# Prizm EFX Lighting
# Xtant Technologies Cooling: Thermal-regulated, turbo charged, intercooler
# Bi-Level RCA Inputs (high/low)
# Variable high-pass filter (40-350 Hz, 24 dB/octave)
# Variable low-pass filter (40-350 Hz, 24 dB/octave)
# CEA-2006 compliant amplifier
# Frequency response: 20-20000 Hz
# Dimensions: 16-11/16" L x 9-5/8" W x 2-1/2"H
# 4-gauge power and ground leads recommended. Contact us for information regarding a discount on a select amplifier kit when purchased together.
O que acham dessa opção?
http://cgi.ebay.com/ebaymotors/Alpine-1-DDT-S30-360W-Soft-Dome-Balanced-Car-Tweeters_W0QQcmdZViewItemQQhashZitem519177b84fQQitemZ350332893263QQptZCarQ5fAudioQ5fVideo
Muito obrigado desde já, Felipe C.
tenho um morel tempo 6 e os tw me agradam muito poderia tentar eles!
Fala Beto beleza?
A minha maior dúvida é em relação as especificações, posso colocar qualquer tweeter?
Tem que ser 4ohms também né? E em relação as frequencias?
Obrigado, abs...
O melhor é saber qual a frequência de corte do crossover do seu kit, se for muito baixa, alguns tweeter´s podem não alcançar. Acho que um NAR TI iria bem no seu caso, ou mesmo um Focal TN44/52, mas esses já teria que ver o corte, pois eles não descem muito como o NAR. Se o crossover do seu kit Alpine tiver corte alto (4Khz ou mais) aí pode is sossegado.
Mais uma opção que eu mesmo tenho vontade de comprar é um TW Vifa de Titânio que tem no ML por R$70,00 cada um. Acho que deve ser um boa opção também.
Ae Leao, justamente quando entrei aqui no tópico para perguntar do NAR TI, vc me posta falando dele,
acho que é um sinal heim, heahea
O pessoal fala bem dele aqui no forum e é um tweeter de fácil acesso. To pensando em manda bala nele mesmo.
Qto a frequencia do crossover, eu n consegui achar nem na caixa do kit nem nos manuais que veio e nem na net,
as especificações que eu achei n passam do que eu ja postei aqui, e nos manuais que vieram com o kit o máximo
que eles informam é sobre o processo de instalação.
Muito obrigado pela ajuda.
