gmrc
DVDS
galera estou com uma duvida no quesito qualidade de audio e video
DVD Clarion VRX485VD / usado porem em estado de novo importado dos eua R$ 1000,00
DVD CLARION
Touch Screen Control with a sophisticated look and feel
The VRX485VD 1-DIN multimedia unit packs a variety of features in a single chassis design. You get compatibility with MP3 and WMA music formats along with direct connection to Sirius Satellite Radio for sound quality that rivals CDs. Connect your iPod® through an available interface cable for full control of audio with the ability to play video files.
DVD-Video/DVD±R/DVD±RW/CD-DA/CD-R/RW ready
MP3/WMA Compatible with ID3-TAG Display
18 FM / 6 AM Station Presets
iPod® Direct Connection and Control (Optional CCUiPod1 Cable Required)
Seek Manual Up/Down
Fully Motorized 7-inch QVGA Color LCD Monitor
Adjustable Display Brightness
Tilt Angle 5 Positions Display
Touch Panel Control
Sirius SSP Direct Connection Ready
24-bit D/A Converter
RCA Visual Input
6ch RCA Output
40 W × 4 Built-in Amplifier
Built-in IR Eye and Remote Included
Sirius SSP Direct Connection READY
ou um DVD KENWOOD KVT 747 / USADO, porem não tão novo, este tem desgastes R$ 900,00
características:
7.0 inch Wide Colour TFT Active Matrix Display
Z-action Monitor Open/Close Mechanism
Motorized Tilt Angle Adjust (8 Step)
Motorized Back and Forth Display Position Adjust (4 Position)
Interactive Touch Panel Control with OSD (On Screen Display)
Multifunction Key Operation
Audio Easy Control Mode while Playing Visual Source
Number of Pixel: 336,960 pixels
Screen Size: W154.1mm X H87.0mm
External Hard-key Operation (When Monitor Closed)
Secondary Display = 5 x 7 Dot Matrix LCD (Colour Selectable: Green, Red & Blue)
Partial Detachable TDF Panel with DSI & Security Code
Selectable Key Illumination (Green/Red)
2nd Generation B.M.S.(Bass Management System) with '02 eXcelon Amplifiers
Digital Clock (KVT-737DVD : 24h, KVT-747DVD/767DVD : 12h)
Supplied with Remote Control Unit (Grip Type with Dual Zone Control)
2-way Telephone Mute
AV Features
Maximum Output Power : 50W x 4 (MOSFET Power IC)
3 Preouts with 5V Pre-output Level
1 RCA AV Output (PAL or NTSC according to the source)
1 RCA AV Inputs + 1 Rear View Camera Input with Reverse Line (PAL/NTSC Automatic Selection)
Rear View Camera Input Signal Mirror Mode (Normal / Reverse)
Video 1 Input Signal Automatic Detection Mode (Normal/ AUTO)
RGB Input for Navigation System
System Q:Sound Control with Pre-programmed Tone Curves
System E's+ (Built-in HPF & LPF)
Dual Zone Source & Volume Control
Attenuator(-20dB) with Smooth Volume Return
Installer Memory/ Backup Memory for Keeping the Customized Setting (even after Reset or Detach from Car Battery)
Single CD Features
DVD Video Player
Direct Touch Operation on DVD Video Menu Screen (Highlight Control Mode) **
VCD Player (Audio Output St/L/R Selectable, Play Back Control Supported)
WMA (Windows Media Audio) & MP3 Files Playback with ID-3 Tag Display
MPEG1/2 Video file (.mpg) and JPEG file (.jpg) Playback
Listed Folder/File Search Function by Touch Panel
CD Text Ready
DVD±R/DVD±RW Compatible
(Playable Formats : DVD Video Format/ MPEG 1&2 Video/ WMA/ MP3/ JPEG File; Single Session Only)
CD-R/CD-RW Compatible
(Playable Formats : Video-CD Format/ MPEG 1&2 Video/ WMA/ MP3/ JPEG File; Multi-Session Possible)
24bit D/A Converter
Random/Repeat/Scan Play
Direct Access with Remote
External Media Control Features
Dual External Media Control Capability (with Optional KCA-S210A)
DNPS (Disc Name Presets) with Compatible CD Changers
CD Text Ready with Compatible CD Changers
Random/Repeat/Scan Play (Disc/Track)
Amp Control System with '04-'05 High-end Amplifiers (Max. 8 Amps Controllable)
-Parametric EQ & Gain Control from Head Unit
-Amp Information Display on Head Unit (Voltage/Current/Temperature/Fan Speed)
Optional Apple iPod Interface Ready (KCA-iP500)
ou é melhor juntar mais uma grana e pegar um Pioneer AVH-P5180DVD / NOVO com garantia R$ 1400,00
Características
Tela de 7" QVGA Wide Screen (Oparação toque na tela)
DVD 1-Din com tela retrátil
Conexões
Conector ISO
Entrada auxiliar traseira
IP-Bus - Compatibilidade com acessórios Pioneer
1 Entrada de vídeo para vcr ou câmera auxiliar (câmera não incluída)
1 Saída ótica digital para dts (processador não incluído)
1 Saída de vídeo rca traseira
1 Entrada de áudio/vídeo rca
Entrada de vídeo RCA para câmera de ré (câmera não inclusa)
2 Saídas RCA
Controle de iPod
MP3 / WMA / AAC
Áudio
Bass Booster (reforçador de graves) de 6 níveis
Eeq equalizador paramétrico de 3 bandas
5 Equalizações pré-definidas
1 Equalizaçõa personalizável
Loudness 3 níveis
Nível máximo de saída RCA de 4V
Display
Ajustes de ângulo de tela
113 opções de cor de iluminação do fundo dos botões
5 opções de iluminação do fundo de tela
Outros
Controle Remoto
Relógio
Beep de operação
Cabo extensor USB de 1,5m incluso
Manual em português
Em questão qualidade de áudio eu iria fácil no Clarion.
entre o kenwood e o pioneer eu ficaria na duvida, mas com o clarion na jogada.....
vlw pelas dicas pessol mais tem um ultimo dvd, que acho muito bonito por ter varios detalhes cromados e pelo designe
Pioneer AVH-P5980DVD
Especificações do Produto:
Potência máxima de saída MOSFET 50W x 4
Display de LCD de 7? com revestimento anti-ofuscamento
Operação com toque na tela
Reprodução de DVD-Video, DVD-R/RW formato Video, CD, CD-R/RW, VCD
Reprodução de arquivos MP3, WMA, AAC iTunes e DivX gravados em CD-R/RW e DVD-R/RW
Controle direto de iPod (áudio e vídeo*) através do cabo CD-I200 (vendido separadamente).
Sintonizador AM/FM
Controle remoto
Display removível com 8 caracteres
Opções de cor do display: vermelho, verde, azul, âmbar e violeta
Opções de iluminação dos botões: azul e vermelha
Conexões:
IP-BUS (compatibilidade com acessórios Pioneer que tenham esta conexão)
1 Entrada AV-BUS
1 Entrada de áudio RCA
1 Entrada de vídeo RCA
1 Entrada de áudio / vídeo (mini jack)
1 Entrada de vídeo para VCR ou câmera auxiliar (câmera não incluída)
1 Saída ótica digital para DTS (processador não incluído)
1 Saída de vídeo RCA traseira
3 Saídas pré-amplificadas RCA (áudio): frente + traseira + subwoofer ? 4 V 100 ohms
Conector ISO
Áudio:
Potência contínua de saída 22W x 4
EEQ ? Equalizador gráfico de 7 bandas
5 equalizações pré-definidas
2 equalizações personalizáveis
Loudness selecionável
LPF / HPF ? filtros de baixa e alta freqüência
Sub-drive direto (possibilidade de ligação de subwoofer sem o uso de amplificador)
Controle de subwoofer
Player de DVD:
Decodificadores MPEG 2/1, Dolby Digital e PCM Linear
DAC 96KHz/24 bit (áudio)
DAC 10 bit (vídeo)
Outros:
Compatível com PAL/NTSC (disco)
Compatível com PAL/PAL-M/SECAM/NTSC (display)
USADO SEMINOVO EM PERFEITO ESTADO, FALTANDO APENAS O CHICOTE RCA E O CONTROLE MAS MUITO NOVO 700,00 REAIS
Editado por gmrc
botão cromado descasca (maldita pioneer), e os vários "detalhes" pode ter certeza q não vão te dar o audio de um clarion <_<
