mariosgj
Hifonics Bxi1606d Ou Mtx Ta-7801
Galera tenho uma prima que mora nos E.U.A e ela compra pra mim na boa, como ja me comprou e me mandou umas coisas da nike e nem precisei paga os 60% de imposto, então to pensando em vender meu 1200d e pega um desses, só queria a opnião de vcs, qual toca com mais qualidade, sem pensar na potencia, somente qualidade, qual desce mais, essas coisas, qual vcs comprariam???
Os dois estão no mesmo preço U$199,99 doletas, ta baratissimo, o frete que vai sair caro mas vale a pena, ela manda por navio pra nao pagar imposto, ja levo esse boi, ta lindo pra mim...
Especificações:
HIFONICS BXi1606D CLASS D 1600 WATTS AMPLIFIER
SPECS:
1 Channel Mono Block operation
550 Watts RMS x 1ch @4 ohms
1100 Watts RMS x1ch @ 2 ohms
1600 Watts RMS x 1ch @ 1 ohm
Turn-On Delay/ Mute
Frequency Response @-3dB: 20-250Hz
Damping Factor: >250
Signal To Noise Ratio: > 95 dB
THD + Noise: < 0.1%
Variable Input Level Control: 0.2V - 9V
Variable Input Level Control: 0.4V - 18V
Input Impedance: 47k Ohm
Input Impedance: 20k Ohm
Power and Specific Diagnostics LEDs
Protection DC, Short Circuit, Overload
Power Supply - All MOSFET: Full PWM
Power Output Circuit Type: Ultra-Fi MOSFET
Variable Phase Shift
Phase Change in Degrees: 0-+180
Variable Low-Pass 24 dB Octave: 35Hz - 250Hz
Variable Subsonic Filter: 15Hz - 35Hz
Bass EQ: 0-+18 dB
Balanced Inputs
RCA Inputs / Line Outputs
Gold Plated Power Terminal Blocks: 4 GA
Gold Plated Speaker Terminal Blocks: 12 GA
Remote bass control included
Dimensions WxHxL: 13.77x2.63x10.39
MTX TA-7801 1200 Watt
Mono Block Amp
This auction is for a Brand New, MTX TA-7801, 1200 Watt (at 1 ohm), Class D Mono Block. This amp is a hoss!!! Pushing out over 1200 Watts of pure, clean power at a 1 ohm load and staying cool as it does it with XTANT Technologies cooling system. This amp comes factory sealed in its original box.
Good Luck and Happy Bidding!!!!!
Features & Specifications:
1200 Watts RMS 1 Ohm
800 Watt RMS 2 Ohm
400 Watts RMS 4 Ohm
Number Of Channels: 1
Built In Crossover: Yes
Thunder Mono high-performance car subwoofer amplifier featuring patented class D output
Xtant Technology Cooling (XTC) - Thermal-regulated turbo-charged fan intercooler
Prizm EFX accent lighting effects - Customizable to match your vehicle's interior
Semi-unregulated MOSFET power supply
Overload and thermal protection
StreetWires connection terminals
Variable electronic crossover at 40~200 Hz, 24 dB/octave Low pass
Bass boost at 40 Hz, 0~12 dB/octave variable
Input (RCA connection): Low-level, hi-level w/Smart Engage
Input sensitivity: 100mV-1V/1V-10V switchable
CEA-2006 Compliant
Dimensions: 20-11/16" L x 9-5/8" W x 2-1/2" H
Wired Bass Knob Included
Abraços...
Mário Junior
qual site que tá esse preço o hifonics?
passaaaaa aiii...
ps: preciso falar qual dos dois ainda?
edit: tinha dado quote
Cara ta esse preço no eBay, mas tem tbm no www.soniceletronix.com e 19 doletas mais caro só...
Mas po qual a diferença? Pq o Hifonics é tão melhor assim??
cara já ouvi mtx e nunca ouvi hifonics..
mtx é muito bom viu, boa qualidade de graves, desce bem, bem bruto..
mas sempre quiz um hifonics
Eu ficaria com o Hifonics ... tem um subsônico que me parece excelente, maios potência, melhor flexibilidade, cross pegando bem baixo ... E os novos MTX só mandam essa potência descrita dentro dos 14V.
PS: não crie mais tópicos iguais em outros sub-fóruns. Essa intenção de receber mais respostas só gera desgosto por partes dos usuários e você fica sem ajuda. O do hi-fi será trancado.
Eu compraria o Hifonics BXi 1606D
Olhando os specs:
Hifonics BXi 1606D-----------------------MTX Audio TA7801
1100 watts RMS 2 ohms------------------ 800 watts RMS 2 ohms
Low-Pass 35 - 250 Hz------------------- Low-Pass 40 - 200 Hz
Subsonic Filter 15 - 50 Hz----------------Subsonic Filter 30 Hz
Signal-to-Noise Ratio 95 dB -------------Signal-to-Noise Ratio 69 dB
So por esse dados eu fico com o Hifonics, seria legal vc trazer um outro ampli da Hifonics tb um de 4 canais pode ser esse Hifonics ZXi 6406
Olhando os specs:
Po se der o dinheiro com certeza compro os dois , heheheh, gostei bastante desse de 4 canais , bem potente...
Eu tava mais pro MTX por ouvir falar aqui no fórum e por ser mais bonito(minha opnião), mas agora vou de Hifonics mesmo, assim que chegar eu posto umas fotos e um video pra galera...
Sobre eu criar outro tópico igual, era pq eu ja ia criar no Hi-Fi ja que eu perguntei sobre a qualidade e acabei criando no Geral por descuido, mas ja que obtive a resposta aqui mesmo, obrigado por ter trancado o outro tópico.
Se houver próxima vez eu mudo o Titulo do tópico pedindo pra trancar pra depois eu criar outro no lugar certo...
Pessoal muito obrigado mesmo pelas respostas,
Mário Junior
Algguem sabe se comprar por PayPal nessa loja é sussegado ?!?!
E outra coisa...
Não tem ninguem que busca produtos nessa loja ?!?!?
Vi uns itens cabulosos lá !!! =D
qq coisa MP pra mim !! =D
Sem duvida os HIFONICS supera o MTX em todo
ja vi muito hifonics tocando e são bruto já o MTX sempre tive um pé atrais com a marca leva muita "fantasia" opnião minha
mais falando da MAXXSONICS
vc quer + qualidade que potencia neh isso? porque vc não pega os MB QUART ou um CRUNCH
http://www.maxxsonics.com
Cara se o preço for o mesmo, quanto mais qualidade melhor, hehehe, eu to indo no hifonics pela promoção que ta né...
Vou ver esse MBQuart, se tiver no mesmo preço ou pouca coisa a mais...
Cada vez vcs me deixam em duvida, aheuihaiuehi...
Obrigado mais uma vez....
Mário Junior
