robson.bruno
    4
Tudo que robson.bruno postou
  1. NÃO ACEITO TROCASCondição: Impecável (sem falhas, avarias ou histórico de reparos)Tempo de Uso: 2 anosMotivo Venda: Mudança para exteriorMT250 - Morel 28mm 6-Ohm Silk Dome Tweeters.+ Brindes:- 1 cabo paralelo Shock Marine Flat 16awg - 5 Mts- 1 cabo paralelo Shock Marine Flat 16awg - 3 Mts- 1 Rastreador/Bloqueador veicular GPS - AccurateVenda somente conjunto (Tweeters + Brindes)############################################################Nominal Impedance (ohm): 4Power Handling (WRMS): 130Max Transient Power Handling W (10ms): 350Sensitivity (2.83 V/1M) dB: 93Frequency Response Hz: 1400 - 24000FS Hz: 1100Voice Coil Diameter mm (inch): 28 (1.125)Voice Coil Former: AluminumVoice Coil Wire: Hexatech AluminumDC Resistance Ohm: 5.2Magnet System: Double Magnet NeodymiumDome Type: Acuflex Hand-Coated Soft DomeDome Material: SilkUnit Diameter mm (inch): 45.00 (1.80)Mounting Depth mm (inch): 20.00 (0.80)Mounting Cutout mm (inch): 50.00 (2.00)
  2. NÃO ACEITO TROCASCondição: Impecável (sem falhas, avarias ou histórico de reparos)Tempo de Uso: 2 anosMotivo Venda: Mudança para exterior################################################Amplificador Italiano Mosconi Gladen One 120.4+ Brindes:- 2 RCA's Nakamichi Stonehenge 0.5 Mt- 2 RCA's Nakamichi Stonehenge 0.7 Mt- 2 RCA's Nakamichi Stonehenge 2.5 Mts################################################Technical FeaturesPower Rating: 120 Watt per channel @ 4 Ohm < 1% THD+NSn Ratio: > 81 dBA (ref: 1 Watt into 4 Ohm)HANDY POWERFUL RANGEThe smallest line with fresh and dynamic young sound recommended also for OEM applications. Absolutely great features on board like Front Stage Adjuster FSA and High Level Input with auto-switch on.Besides, thermo controlled fans and Plug & Play wiring harness (optional).Low Level (LL) and High Level (HL) inputTarget powers:120 Watt per channel @ 4 Ohm170 Watt per channel @ 2 Ohm340 Watt BTL mode @ 4 OhmInput sensitivity: (Power rating ref)0.35 V ÷ 16 VXover functions: (HIGH Pass or LOW Pass)HIGH Pass or LOW Pass(45 ÷ 225 Hz – 12 dB/oct)Special Features:Remote Volume Control (optional)Front Stage AdjusterPhase Shift 0° ÷ 180° (Rear)High Low AdapterSize:310x200x50 mmWeight:2,7 Kg https://produto.mercadolivre.com.br/MLB-1650276843-amplificador-modulo-mosconi-gladen-ital-one-1204-brindes-_JM#position=2&type=item&tracking_id=1c11a07c-64f5-44cc-84f0-875d0cf2cd45
  3. VENDIDO. Favor excluir. Obrigado! NÃO ACEITO TROCAS Condição: Impecável (sem falhas, avarias ou histórico de reparos) Tempo de Uso: 2 anos Motivo Venda: Mudança para exterior Processador de Audio Italiano Mosconi Gladen DSP 4t06 - SP_DiF com chave externa para seleção de até 4 Presets. + Brindes: - 2 controles externos para controle volume MASTER e SUB (5Mts) - 2 Cabos paralelos Lautsprecherkabel 16awg - 4 Mts (RCA Hi Level Input) - 1 Roteador WiFi Apple AirPort Express (Alimentação USB) para conexão (AirPlay) com iPad/iPhone/iPod + Cabo Fibra (MiniJack Monster Cable) para instalação Óptica digital com o processador. Qualidade de áudio impressionante ! ############################################################ Venda somente conjunto (Processador + Brindes) ############################################################ Product highlights: Designed and made by MOSCONI, Italy Stand Alone Processor The Digital Signal Processor with 4 inputs and 6 outputs. GLADEN DSP 4to6 Highest resolution, e.g. time delay in 0,02 msec/step, Q in steps of 0.001 Parametric and Graphic EQ with up to 30 (para-graphical) bands per channel pair All settings in real-time USB and BT adapter (MOS-BTM), for adjusting by PC and Android smart phone apps Low-level or High-level input with auto-sense (only by High-Level) Aux input with auto-sense for stereo signal Hands-free and mobile navigation 4 presets Mixer matrix to realize all possible mixtures and couple input and output channels as desired Intuitive User Interface and video tutorials to avoid an instruction book. Operating also without mouse, only with keys for an easy adjusting in the car DSP Technology made by cooperation MOSCONI-GLADEN SP-DiF: Digital input output Digital inputs optical and coaxial SP-Dif SP-Dif output (optical) with volume-regulated signal from channel 1+2. Technical Specifications: INPUT MODE: Low Level (LL) / High Level (HL) INPUT IMPEDANCE: > 10Kohm (LL) / 47ohm (HL) INPUT SENSITIVITY: 2Vrms ÷ 8Vrms (LL) / 5Vrms ÷ 20Vrms (HL) INPUT VOLTAGE REGULATION: -12dB ÷ 0dB MAX OUTPUT SIGNAL: 4Vrms OUTPUT IMPEDANCE: 50 ohm THD DISTORTION: FREQUENCY RESPONSE: 20Hz ÷ 20KHz (within -0.1dB) CHANNEL SEPARATION: >75dB (@ 1KHz) SUPPLY VOLTAGE: 11V ÷ 15V CURRENT CONSUMPTION: 0.5A @ 12V GROUND ISOLATION vs CAR BODY: 1Kohm AUTOSENSE: two operative modes (yes, HL only) REMOTE OUTPUT: 130mA max. COMMUNICATION PERIPHERALS: on-board USB, Bluetooth socket, Remote controller SIZE: 150 x 125 x 40 mm (including fixing feet) https://produto.mercadolivre.com.br/MLB-1650303023-processador-audio-ita-mosconi-dsp-4to6-optical-in-brindes-_JM#position=1&type=item&tracking_id=649e7501-50eb-4486-ad1d-38e5e561446e
