japinha.1982
    8
Tudo que japinha.1982 postou
  1. valew ae pela dica .......... vou ver se faco o que vc me falou .............
  2. entao galera eu to no Japao e a caixa fiz a recomendada pela JL com 49 litros cada lado e meu modulo eh o Lanzar vibe de 1800 w e a caixa ta sintonizada 35hz ............. mas enfim to achando que deve ser a regulagem......... alguem pod me falar como regulo o modulo ............valew
  3. entao bloom eu fiz uma caixa com 49 litros cada falante recomendada pelo site da JL com mdf 21mm com duto retangular .......... mas nao sei se eh a regulagem ou o carro que nao deixa sair o grave quando ta andando tipo disparar alarme ............ a caixa ta sintonizada 35hz segundo o site.....
  4. W7 8W7 10W7 12W7 13W7 W6v2 10W6v2 12W6v2 13W6v2 TW5 13TW5 W3v3 6W3v3 8W3v3 10W3v3 12W3v3 13W3v3 W1v2 8W1v2 10W1v2 12W1v2 13W1v2 W0v2 10W0v2 12W0v2 15W0v2 WX 10WX 12WX Discontinued Mounting System Reviews W7 Technologies Recommended Power Chart Tutorials 12W7 ENCLOSURE SPECIFICATIONS Net volumes given below do not include the air volume displaced by the speaker (Driver Displacement). This value must be added to the net volume along with the displacement of any braces and/or ports (if applicable) to arrive at a gross internal volume. Air inside a port is not part of the effective net volume. Calculate ports as solid, not hollow objects. The dimensions given for the enclosure examples below take all applicable displacements into consideration. SAFETY NOTICE! It is absolutely essential that the completed subwoofer enclosure is mounted firmly to the vehicle with heavy steel bolts (1/2 inch diameter) and large steel washers on both sides of the bolts. This will reduce the likelihood of occupant injury in the event of a collision or sudden deceleration. Front Baffle Thickness 1.0 in. / 25 mm Wall Thickness 0.75 in. / 19 mm Recommended Sealed Enclosures Subwoofer Volume (net int.) External Dimensions (Width x Height x Depth) F3 (Hz) Fc (Hz) Qtc 12W7-3 1.375 cu. ft. / 38.94 liters 16 in. x 19 in. x 11.75 in. 406 mm x 483 mm x 299 mm 40.4 44.7 0.792 Front Baffle Thickness 1.0 in. / 25 mm Wall Thickness 0.75 in. / 19 mm Recommended Ported Enclosures Subwoofer Volume (net int.) External Dimensions (Width x Height x Depth) Slot Port Internal Dimensions (Slot Width x Slot Height x Slot Length) Port Extension Length (EL) Tune to: (Hz) F3 (Hz) 12W7-3 1.75 cu. ft. / 49.56 liters 22.75 in. x 15.5 in. x 15.5 in. 578 mm x 394 mm x 394 mm 1.75 in x 14 in x 24.0 in. 44 mm x 356 mm x 610 mm 8.5 in. 216 mm 36.7 31.5 Click here to download the owner's manual (PDF). PURCHASING JL AUDIO PRODUCTS VIA THE INTERNET Sign-up for updates Copyright © 2010 JL Audio, Inc. - All rights reserved | Privacy Policy a caixa e essa ai
  5. eu tenho um kit duas vias focal polyglass 165v2 um modulo estereo audison 4.300 um modulo lanzar vibe 1800 mas o modulo mono to querendo tracar por um rockford fosgate 1500 ...........eh mais ou menos isso ai
  6. e ae galera eu me expressei mal .......... eu queria dizer que queria com o porta mala fechado ...........mas que o grave saisse entende........tipo assim que disparasse o alarme ............ valew desculpe os erros de portugues mas eh q to fora do brasil a algum tempo
  7. e ae galera eu queria saber quantos litros devo fazer a caixa e tal....... pra dar um grave forte pra dentro e pra fora ......pois fiz a caixa recomendada pela JL no site mas da grave pra dentro nao sai muito entende ......... se puderem me ajudar agradeco falow
