Hein! eu curto sertanejo e Dance, E optei por apenas sub de 12'' ou 15''. Vo pegar no py mesmo pelo custo!
Qual desses seria melhor opção?
MTX TR5515-04 15 "Single 4 ohms Subwoofer TR55 Trovão Série Redonda
Potência:
Pico: 900 watts
RMS: 450 watts
Impedância: 4 ohm Único
Woofer com cone de polipropileno
Costurado NBR envolvente
Die-cast, cesta de alumínio estampado
8-manómetro de compressão terminais de níquel
Borracha bota ímã
ALDS (sistema de transmissão assimétrica Linear)
Aranha progressiva plana
Pólo estendido para o bom, o pistão, linear, como unidade
Exclusivo aranha planalto ventilação sistema de refrigeração
2 "de alta temperatura única Bobina de 4 ohms
81 onças ímã
Resposta de freqüência: 29-150 Hz
Sensibilidade: 85 dB
Jbl GTO 1514
Subwoofer Size 15"
Subwoofer Design Round / Circle
Main Cone Color Black Silver
Voice Coil(s) Dual
Impedance (per voice coil) 4 ohms
Peak Power Handling 1400 watts
RMS Power Handling 350 watts
Woofer Composition Polypropylene
Woofer Surround Rubber
Minimum Sealed Box Volume 1.5 cubic feet
Maximum Sealed Box Volume 1.5 cubic feet
Minimum Ported Box Volume 3.5 cubic feet
Maximum Ported Box Volume 3.5 cubic feet
Sensitivity 96 dB
Frequency Response 23 - 400 Hz
Xmax (millimeters) 15 mm
Top Mount Depth 6-13/16"
Shallow Mount Installation No
Cutout Diameter 13-15/16"
Recommended Enclosure Type Ported / Vented or Sealed
SUB kicker CRV15
Impedance: Dual 2 Ohm
Injection molded SoloKon cone
Ribbed Santoprene surround
Double stitched surround for enhanced cone-to-surround strength
Extra strong adhesive and stitching prevents the cone from detaching
from the surround
Spiralead tinsel lead technology weaves the tinsel leads into the spider
Progressive-roll polycotton spider
Super rigid cone and 360-degree back bracing eliminate distortion
Sturdy steel basket holds the subwoofer mounted firmly
Steel basket features perimeter venting around the dual voice coils
Large, high-mass pole piece for dissipating potentially damaging heat
Strong spring-loaded terminals
Newly re-designed 2010 basket structure
High-Temperature voice coil
Powerful rear magnet
Frequency response: 25-500 Hz
Sensitivity: 89.2 dB
Mounting depth: 8-3/16
Also found as: 10CVR15-2 ohm, CompVR152, CVR-152, CVR-15, CompVR 152,
CompVR 15" 2 ohm, 2010 CVR152
