Juniorpth
((Vendido)) pode fechar! Kit 2 Vias Rockford Fosgate T1652s
Vendo Kit 2 Vias Rockford Fosgate T1652s
Valor R$ 799,99
Funcionamento perfeito!
  • 6-1/2" T1 Series 2-Way Component System
  • Power Handling:
  • Peak: 400 watts per set / 200 watts each side
  • RMS: 200 watts per set / 100 watts each side
  • Recommended Amplifier RMS Power: 30-100 watts
  • Carbon fiber and polypropylene injection molded cone
  • Butyl rubber surround
  • 1" Aluminum dome tweeter with polyurethane suspension
  • Tweeter has 3 levels of attenuation
  • On-axis/off-axis tweeter configuration
  • Positive Temperature Coefficient (PTC) Protects the tweeter with a bypass resistor
  • Discreet Dual Clamp (DDC) Tweeter mounting system for simplified installation
  • FlexFit basket design allows for variable mounting positions
  • VAST surround provides up to 25% more surface area of the cone
  • Bi-amp on/off capability
  • External audiophile grade component crossover
  • 5% tolerance high quality poly-capacitors and air-core inductors
  • 4 ohms impedance
  • 1-1/16" Voice coil
  • Speaker grilles included
  • Includes an OEM 6" x 9" and 5" x 7" adapter plate for simple installation
O kit está bem conservado!
Em casos de dúvidas, estou à disposição!
http://produto.merca...gate-t1652s-_JM
Editado por Juniorpth
Visitante
