ticominero
[ajuda] Qual Player Entre Esses 2?
Pessoal estou com uma grande duvida... apos roubarem meu player comecei a pesquisar e verifiquei que estes dois player cabem em meu orçamento, e os outros na faixa de preço perto nao chegaram nem aos pes deles. porem nao sei qual dos dois é melhor.
Ate agora o que consegui descobrir e que o 4900 é da linha americana, e o 5950 é da linha australiana (????).
As especs deles seguem abaixo
Pioneer DEH-P5950IB
http://www.pioneer.com.au/products/car_ent...ners/index.html
CD Features
Playback for MP3, WMA and WAV Files
Playback for AAC Files (as used by iTunes)
ID3 Tag Recognition
BMX (BiMetric Equalizer)
Digital Compression selection
CD-R and CD-RW Compatible
Disc Title Memory w/10 characters (48 discs)
1-Bit D/A Converter, 8fs Digital Filter
CD Text Display with Auto Scroll function
Track Scan, Pause ,Repeat
Random Play
Track / Manual Search
Pioneer DEH-P5950IB Audio Features
MOSFET 50 Watts x 4 high power
Rotary Volume Control
EEQ (Easy Equalizer)
3-Band Parametric EQ within EEQ
Selectable Frequency and Q for EQ adjustments
5 Preset + 1 Custom EQ Mode
FIE (Front Image Enhancer) @100/160/250Hz
Bass Booster : 0 ~ 12dB in 2dB steps
LPF Subwoofer Crossover (-24~+6dB by 1dB)
50/ 63/ 80/ 100/ 125Hz @ -18dB/oct.
Normal/Reverse Subwoofer Phase Selection
Direct Subwoofer Drive (from headunit power)
HPF (High Pass Filter)
50/ 63/ 80/ 100/ 125Hz @ -12dB/oct.)
Selectable 3-Mode Loudness Control
Electronic Volume / Balance / Fader controls
SLA (Source Level Adjuster)
Attenuation button not featured
3 pairs RCA Preout (Front + Rear + Subwoofer)
Pioneer DEH-P5950IB Connectivity
AUX Input jack on rear panel (Ø 3.5mm)
External Source, TV, DVD, CD Control
AUX Input via CD-RB10 or CD-RB20
Direct iPod Control (via supplied CD-I200 - shown)
Bluetooth adapter ready (via EXT)
USB adapter ready (CD-UB100 via EXT)
DAB (Digital Audio Broadcasting) External Tuner Control
Display output for OEM integration (adapter req’d.)
Multiplay CD Control (CDX-P680 etc.)
CD Text Display with Title Scroll
ITS (Instant Track Selection)
Disc Title Memory
Track & Disc Scan
Repeat Play (Track/Disc/Mag)
CD Pause
Random Play (Disc / Magazine)
Digital Compression selection on MCD
Pioneer DEH-P5950IB Additional Features
Card IR Remote Control
Flap-type DFS (Detachable Face Security)
DFS Hard Carry Case included
Operation Beep Tone and Detach Face Warning Beep
Two-line (2 x 16 char.) Pure Blue OEL display
Display Dimmer control
Green button illumination, Pure Blue for Rotary Control
Clock and Calendar
PIONEER DEH-P4900IB
http://www.pioneerelectronics.com/pna/v3/p...etailsComponent
Supertuner (AM/FM Radio)
Supertuner Supertuner IIID
24-Station/6-Button (18FM/6AM) Presets
BSM (Best Stations Memory)
Local Station Setting Selectable (4-Step)
Satellite Radio Capability
XM Radio Ready Yes (GEX-P920XM Required)
Sirius Radio Ready Yes (SIR-PNR2 Required)
CD Player
1-bit D/A Converter Yes (8fs/16-bit)
CD-R/CD-RW Compatible
AGC (Automatic Gain Control)
Disc Title Memory
Disc List
CD Text CD Text
BMX Digital Enhancement
MP3 Playback Compatibility
Codec Support MP3, WMA, WAV, iTunes AAC
File System ISO9660-1,-2, Romeo, Joliet
Max Directory 8
Max. Folder # 99
Max File # per Disc 999
Multisession Disc Play
Random Play Folder/Disc
Repeat Play File/Folder
MP3 Bit Rate 8~320kbps or VBR
WMA Format WMA v7, 8, 9, 10
WMA Bit Rate 48~384kbps, VBR
AAC Format iTunes AAC
AAC Bit Rate 16~320kbps
File Name 64 bytes
Folder Name 64 bytes
ID3/WMA Tag ID3 v1.0, 1.1, 2.2, 2.3, 2.4; WMA; iTunes AAC
Tag Length 64 bytes
Tag Data Track, Artist, Album, Comment
Tag Display On/Off
List Search Folder
Bluetooth Capability
Bluetooth Capable Yes (CD-BTB200 Required)
Hands-Free Profile (HFP) (w/CD-BTB200)
Audio Streaming Profile (A2DP) (w/CD-BTB200)
Audio Control Profile (AVRCP) (w/CD-BTB200)
iPod Control Capability
iPod Control Capability "iBus" Direct Control (CD-I200 Required)
Additional System Expandability
IP-Bus System Control
USB Control Capability Yes (CD-UB100 Required)
Multi-CD Control
DVD Control
TV Tuner Control
Display Output
Built-in Auxiliary Input Built-in (Rear)
Optional (IP-Bus) Auxilary Input CD-RB10 or CD-RB20 required
External Unit Control 2
Display Features
Face Type Flap Face
Display Type Segmented Organic EL (OEL)
Dot Matrix OEL Size 2 Line x 16 Characters
Button (Key) Illumination Green + Blue
Audio Features
Built-in Speaker Power MOSFET 50W x 4
Continuous Power Output 22W x 4
Equalizer EEQ (3-Band Parametric)
Equalizer Presets 5
User Equalizer Settings 1
Loudness 3 Mode
Electronic Balance/Fader
Source Level Adjuster (SLA)
Crossover Network Two-Way Crossover
High-Pass Crossover (HPF) 50/63/80/100/125Hz, -12dB/Oct.
Subwoofer Crossover (LPF) 50/63/80/100/125Hz, -18dB/Oct., +/-12dB
Subwoofer Direct Control Key
RCA Preouts 3 pair (Front, Rear, Sub/Non-Fading)
Preout Voltage & Impedance Hi-Volt (4V), 100 ohm
General Features
Volume Control Rotary Knob
Operation Mode Cross-Key
Remote Control Card
Wired Remote Input
Warranty 1 Year
E ae pessoal vcs que entendem das coisas aqui, o que falam? qual sera melhor?? nao consegui achar mta diferença nao...
Desculpe pelo post gigante, eh que eu queria passar o maximo de informaçoes.
Abraços e mto obrigado pela ajuda
Ah, esqueci de avisar, os dois esteticamentes sao quase identicos, portanto nao teria como escolher por estetica...
Agradeço aos que ja viditaram mas como eu nao conseguiram chegar em uma resposta
Tem muito pouca dif entre os dois, se a diferença for pequena vai de 59xx, pois a frente dele é automatica. Agora veja a dif entre o 69xx, esse tem visor colorido, cortes maiores, e equalizador 7 banda.. esse sim valeria bem mais a pena.
[]'s
Nitrous
[]'s
Nitrous
intendi, os dois tem o mesmo preço... a mesma frente, portanto o q faria diferença sao esses dealhes...
o 69xx o preço ja sobe mto... pra minha renda fica fora de mao...
por enquanto intaum vou ficando com o 5950!!!
Valeu Nitrous
Cara eu iria de 490IB, ta na na faixa de 400 a 450, se não me engano vi no somcuritiba por R$399 e tbm to pensando em pegar um...
Qual o preço que vc tem neles, eu acho muito mais negócio o premier 490IB, e nele todos os leds são azuis, mto mais bonito e o RCA dele é 4v...
Cara to ligado do 490, mais esse que eu estou falando é 4900, nao é da linha premier... eu consigo ele ou o 5950 por 330!!!
Grande abraço
Grande abraço
Dei pro meu irmão um Premier 490IB, paguei $325...
Tenho um DEH-6750, liguei no meu set rapidinho, achei bem melhor, a saída de 4v vale a pena...
Grande abraço
Olá!
Se você puder escolher o 5900IB no lugar do 5950IB seria uma opção. Ele tem 7 equalizações também, bem como 3 pares de saidas RCA a 4v.
Grande abraço
Cara aonde vc conseguiu por esse preço? Qualquer coisa me manda uma mp pq ta fo** saber qual player comprar.... so to com 350!!! O resto ta indo pros outros equips...
Valeu
