[Nakamichi]NAKAMICHI NRO-D1500.1 CLASS-D MONO BLOCK POWER AMPLIFIER SPECIFICATIONS Amplifier Class:D N-Power Output @1ohm(T.H.D.10%...
291064059_3390452411190850_6893234345761680564_n.jpg?stp=dst-jpg_p526x296&_nc_cat=103&ccb=1-7&_nc_sid=8024bb&_nc_ohc=CJkcWTviHyoAX_6jkn9&_nc_ht=scontent-maa2-2.xx&oh=00_AT8LzUtNU9ZczbZo5SsIuVOthq4iWs2jGvqnibw-teGxNA&oe=62C09934
NAKAMICHI NRO-D1500.1 CLASS-D MONO BLOCK POWER AMPLIFIER SPECIFICATIONS Amplifier Class:D N-Power Output @1ohm(T.H.D.10%): 1500W x 1 N-Power Output @2ohm(T.H.D.1%): 800W x 1 N-Power Output @4ohm(T.H.D.1%): 400W x 1 Max Power: 9000W Frequency Response: 10Hz - 20kHz Low Pass Cross Frequency: 80Hz-20kHZ High Pass Cross Frequency: 10Hz-80HZ Bass Boost: 0dB - 10dB Minimum Impedance : 20KΩ Signal To Noise Ratio: ≥90dB Input Sensitivity: 200m V~ 5 V Distortion (THD): ≤0.2% Fuse Size: 100A x 1 Net Weight: Approx. 1.9kg Unit Dimension (LxHxW): 185x190x54mm
